I tried to update Tensorflow node from version 0.2.2 to 0.3.1
Unfortunately it failed with the following error messages:
2022-11-30T15:39:17.678Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-tensorflow@0.3.1
2022-11-30T15:39:18.353Z [err] npm
2022-11-30T15:39:18.354Z [err]
2022-11-30T15:39:18.354Z [err] WARN config production Use `--omit=dev` instead.
2022-11-30T15:39:53.829Z [err] npm
2022-11-30T15:39:53.829Z [err] ERR! code 1
2022-11-30T15:39:53.830Z [err] npm
2022-11-30T15:39:53.830Z [err] ERR!
2022-11-30T15:39:53.830Z [err] path
2022-11-30T15:39:53.830Z [err] /var/db/nodered/node_modules/@tensorflow/tfjs-node
2022-11-30T15:39:53.833Z [err] npm
2022-11-30T15:39:53.833Z [err] ERR! command failed
2022-11-30T15:39:53.833Z [err] command sh /tmp/install-a28218cb.sh
2022-11-30T15:39:53.833Z [err] ERR! /var/db/nodered/node_modules/@tensorflow/tfjs-node/scripts/deps-constants.js:86
2022-11-30T15:39:53.833Z [err] ERR! throw Exception('Unsupported platform: ' + os.platform());
2022-11-30T15:39:53.833Z [err] npm ERR! ^
2022-11-30T15:39:53.834Z [err]
2022-11-30T15:39:53.834Z [err] npm ERR!
2022-11-30T15:39:53.834Z [err] ReferenceError: Exception is not defined
2022-11-30T15:39:53.834Z [err] at Object.<anonymous> (/var/db/nodered/node_modules/@tensorflow/tfjs-node/scripts/deps-constants.js:86:3)
2022-11-30T15:39:53.834Z [err] at Module._compile (node:internal/modules/cjs/loader:1109:14)
2022-11-30T15:39:53.834Z [err] at Object.Module._extensions..js (node:internal/modules/cjs/loader:1138:10)
2022-11-30T15:39:53.834Z [err] at Module.load (node:internal/modules/cjs/loader:989:32)
2022-11-30T15:39:53.834Z [err] ERR! at Function.Module._load (node:internal/modules/cjs/loader:829:14)
2022-11-30T15:39:53.834Z [err] ERR! at Module.require (node:internal/modules/cjs/loader:1013:19)
2022-11-30T15:39:53.834Z [err] ERR! at require (node:internal/modules/cjs/helpers:93:18)
2022-11-30T15:39:53.834Z [err] ERR! at Object.<anonymous> (/var/db/nodered/node_modules/@tensorflow/tfjs-node/scripts/install.js:36:5)
2022-11-30T15:39:53.834Z [err] ERR! at Module._compile (node:internal/modules/cjs/loader:1109:14)
2022-11-30T15:39:53.834Z [err] ERR! at Object.Module._extensions..js (node:internal/modules/cjs/loader:1138:10)
2022-11-30T15:39:53.837Z [err]
2022-11-30T15:39:53.838Z [err] npm ERR!
2022-11-30T15:39:53.838Z [err] A complete log of this run can be found in:
2022-11-30T15:39:53.838Z [err] npm ERR! /var/db/nodered/.npm/_logs/2022-11-30T15_39_18_297Z-debug-0.log
2022-11-30T15:39:53.893Z rc=1
The line that took my special attention was:
where "Unsupported platform" was in red.
This could very well be the case, as I tried to run it in a TrueNAS (FreeBSD) jail on a
HP Micro Gen 8 server. Anyone can confirm that version 0.2.2. is the latest that should run on FreeBSD platform. Any hint to solve it, is also welcome.
