When I use this node "node-red-contrib-usbcamera" it generates a path output to /home/perigalacticon/Pictures/image01.jpg but the photo is not there. How do I make this work?
What have you tried? Can you create a small flow showing the problem? If so export t and attach it to a reply.
In addition
- What version of Node-REDD and node.js are you running (you can get this from the NR start up log)
- what device and OS is NR running on?
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
code goes here
You can edit and correct your post by clicking the pencil
icon.
I see you have opened an issue on the node's GitHub page. But seeing that this node has not been updated if 7 years, it looks like it has been abandoned.
