Node red convert string to fields
Hello i want a way to convert my string data into Json fields where they can be read by things speak
maybe the json node :wink:
when i do that i get this error
before the split ?
same things
so what is going into the split ? What is the split actually splitting up ? is that a string ? can you just paste that string ?
before splitting is this ,the decrypt payload is just to decrypt the binary array
But no matter - a function after the split like this - should do it (instead of the json node)
var m = msg.payload.split(':');
msg.payload = {};
msg.payload[m[0]] = m[1];
thank you i appreciate it now i have like that but i cant get any entries in the thingspeak using thingspeak42
No idea - never used that node - - looks like it is actually asking for topics with values not an object ... so I'd guess maybe this instead...
msg.topic = m[0];
msg.payload = m[1];
but I've never used it - so you'll have to read their docs.
thank you very much
now at least has data queuing but am getting this error
Lookup http error 400. I think it means not allowed (is bad credentials)
400 (Bad request) The server didn't understand the syntax of the request.
i put all credential right i looked it up there is no solution
