After installing node-red-contrib-speedtest node-red is crashing the whole Time:
● node-red.service - Node-Red
Loaded: loaded (/etc/systemd/system/node-red.service; disabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2018-07-28 22:46:52 BST; 6s ago
Process: 3918 ExecStart=/usr/local/bin/node-red -u /mnt/dietpi_userdata/node-red (code
=exited, status=1/FAILURE)
Main PID: 3918 (code=exited, status=1/FAILURE)
Jul 28 22:46:51 DietPi node-red[3918]: file using your chosen key the next time you deploy a cha
nge.
Jul 28 22:46:51 DietPi node-red[3918]: ---------------------------------------------------------
Jul 28 22:46:51 DietPi node-red[3918]: 28 Jul 22:46:51 - [info] Starting flows
Jul 28 22:46:52 DietPi node-red[3918]: 28 Jul 22:46:52 - [info] Started flows
Jul 28 22:46:52 DietPi node-red[3918]: 28 Jul 22:46:52 - [red] Uncaught Exception:
Jul 28 22:46:52 DietPi node-red[3918]: 28 Jul 22:46:52 - Error: bind EADDRINUSE 0.0.0.0:5353
Jul 28 22:46:52 DietPi node-red[3918]: at _handle.lookup (dgram.js:282:18)
Jul 28 22:46:52 DietPi systemd[1]: node-red.service: Main process exited, code=exited, s
tatus=1/FAILURE
Jul 28 22:46:52 DietPi systemd[1]: node-red.service: Unit entered failed state.
Jul 28 22:46:52 DietPi systemd[1]: node-red.service: Failed with result 'exit-code'.
