Hi there,
does anyone know where the theme library folder is stored on disk?
I would like to include my custom dashboard theme into a docker container preselect-able.
cloud not find it using cd ... ls -l.... over and over again in several locations..
Thanks a lot
it will be under ~/.node-red/lib/themes
Nick
Hi Nick,
Thanks for Your help
since I Use Node-Red on a Docker Container, I just found it under the /data folder.
I was expecting it under /.node-red/lib/themes, as you wrote
have a Good afternoon
and thanks again
Philipp
Yup - the complete answer should have been the location is <node-red-user-directory>/lib/themes - and for most users, <node-red-user-directory> is ~/.node-red, but the docker container uses /data.
Yah, I'm working my self into Docker right now, and volumes was not on my list jet, but is now
That would have saved an Hour of stupid searching
