With a ui_slider node connected to a debug node and set to:
It seems to be sending an output before release (while dragging, or at first click), is this expected behavior?
Yes, I have the same issue. When starting to slide, the slider often sends an initial changed value, +/- 1 compared to the original one, which is a greaet problem, when the slider initiates a process that takes some time to complete
This seems to have been addressed before, but still an issue (on iOS 15.3.1)
https://github.com/node-red/node-red-dashboard/issues/519
