hello everyone, is there a way to deactivate individual flows with a command? so that I can automatically deactivate and reactivate it ..?
Here is the way to deactivate the flow via ui
and programatically i think there is no direct option. Please correct me if im wrong.
i would use the runtime api to get the flow, add the disabled option and set the flow with the api again.
https://nodered.org/docs/api/modules/v/1.0/@node-red_runtime_flows.html#.getFlow
What is your context @automati ? Where do you want to disable the flow? From a node within a flow or with another application?
