Hi
Is there a way within node-red to change the sensitivity of a Hue Outdoor Motion sensor which is connected via a ConBee through DeConz?
Hi
Your question would be easier to answer with a few more details. What node are you using to get the data into NR? Once you get it in NR you could use the range node to change the range of the data...
But if you are asking to change the actual sensitivity on the sensor itself, you should look at the documentation of the sensor and see if and how you can do that.
