I haven't been successful trying to get Node RED (node-red-contrib-home-assistant-websocket) to connect to Home Assistant for a while now.
I'm running HA 2022.12.6 and Node RED 3.0.2 with node-red-contrib-home-assistant-websocket 0.47.1.
Running the node-red container in bridge mode with port 1880 forwarded results in not finding the HA instance in the web UI. Adding the server manually nets: "Deploy a valid server config for autocomplete to show results."
When running it in host mode, the HA instance is found. Adding it still nets the above-mentioned message and no autocomplete results.
Running
sudo docker exec -it nodered bash
ping *homeassistant*
echo < /dev/tcp/*homeassistant*/8123
works both in host mode and in bridge mode.
Configuring the logging output in data/settings.js to
logging: {
console: {
level: "trace",
does not help either.
docker compose logs -f nodered
does not yield any info regarding the home assistant integration.
Docker is running on a single host machine. Using one compose file versus two separate ones does not change the outcome.
compose.yaml for node-red
services:
nodered:
container_name: nodered
image: nodered/node-red:latest
restart: unless-stopped
volumes:
- ./data:/data
ports:
- "1880:1880"
compose.yaml for Home Assistant
services:
homeassistant:
container_name: homeassistant
image: "ghcr.io/home-assistant/home-assistant:stable"
volumes:
- ./homeassistant:/config
network_mode: host
I'm not a pro, but here is my docker compose.yaml file.
Node red is functioning with this. (on a pi4 with raspios 64bit).
Working from de base directory /opt.
I followed this tutorial to install and configure the all of my stuffs : http://sequr.be/blog/
file :
services:
portainer:
container_name: portainer
image: portainer/portainer-ce:latest
ports:
- "9000:9000/tcp"
- "9443:9443/tcp"
environment:
- TZ=Europe/Brussels
volumes:
- /etc/localtime:/etc/localtime:ro
- /var/run/docker.sock:/var/run/docker.sock
- /opt/portainer/data:/data
homeassistant:
environment:
volumes:
- /opt/homeassistant/config:/config
- /run/dbus:/run/dbus:ro # <-- Bluetooth adapter
privileged: true
network_mode: host
depends_on:
- mariadb
- influxdb
- mosquitto
mariadb:
container_name: mariadb
image: mariadb
ports:
- "3306:3306/tcp"
environment:
- MYSQL_ROOT_PASSWORD=${MYSQL_ROOT_PASSWORD}
- MYSQL_DATABASE=${MYSQL_HA_DATABASE}
- MYSQL_USER=${MYSQL_HA_USER}
- MYSQL_PASSWORD=${MYSQL_HA_PASSWORD}
volumes:
- /opt/mariadb/data:/var/lib/mysql
- /opt/mariadb/config/:/etc/mysql/conf.d
influxdb:
container_name: influxdb
image: influxdb
ports:
- "8086:8086/tcp" # So we can access the WebUI
environment:
- DOCKER_INFLUXDB_INIT_MODE=setup
- DOCKER_INFLUXDB_INIT_USERNAME=${INFLUXDB_USER}
- DOCKER_INFLUXDB_INIT_PASSWORD=${INFLUXDB_PASSWORD}
- DOCKER_INFLUXDB_INIT_ORG=${INFLUXDB_ORG}
- DOCKER_INFLUXDB_INIT_BUCKET=${INFLUXDB_BUCKET}
volumes:
- /opt/influxdb/data:/var/lib/influxdb2
- /opt/influxdb/config/:/etc/influxdb2
ulimits:
nofile:
soft: 32768
hard: 32768
hass-configurator:
container_name: hassconf
image: causticlab/hass-configurator-docker
ports:
- "3218:3218/tcp"
volumes:
- /opt/hassconf/config:/config
- /opt/homeassistant/config:/hass-config
depends_on:
- homeassistant
adminer:
container_name: adminer
image: adminer
ports:
- "8080:8080/tcp"
depends_on:
- mariadb
mosquitto:
container_name: mosquitto
image: eclipse-mosquitto
ports:
- "1883:1883/tcp"
environment:
volumes:
- /opt/mosquitto/config:/mosquitto/config
- /opt/mosquitto/data:/mosquitto/data
- /opt/mosquitto/log:/mosquitto/log
stdin_open: true
tty: true
nodered:
ports:
- "1880:1880/tcp"
environment:
volumes:
- /opt/nodered/data:/data
depends_on:
- homeassistant
- mosquitto
duplicati:
container_name: duplicati
image: duplicati/duplicati
ports:
- "8200:8200/tcp"
environment:
volumes:
- /opt/duplicati/data:/data
- /mnt/backup/duplicati:/backups
- /opt:/source
esphome:
container_name: esphome
image: esphome/esphome
ports:
- "6052:6052/tcp"
environment:
# mDNS doesn't work across VLANs, use static IP for devices when disabling mDNS
# - ESPHOME_DASHBOARD_USE_PING=true
volumes:
- /opt/esphome/config:/config
# devices:
# - /dev/ttyUSB0:/dev/ttyUSB0
network_mode: host
zigbee2mqtt:
container_name: zigbee2mqtt
image: koenkk/zigbee2mqtt
ports:
- "8099:8099/tcp"
environment:
volumes:
- /opt/zigbee2mqtt/data:/app/data
- /run/udev:/run/udev:ro
devices:
- /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0:/dev/ttyACM0
I've forgotten :
to access HA with nodered , when launched, install the "node-red-contrib-home-assistant-websocket" palette, and use don't thick the "Using the Home Assistant Add-on" box. Just create a long term Access token in HA and use it when creating the HA server in nodered. (and install nodered companion in ha too)
This is functional for me.
system
Closed
11 January 2023 20:43
5
