Hi, Thanks for you respons, I am running on a browser chrome I have tried different browsers and removed all the cache, unfortunately it dit not do the trick
This is the start up message :
Welcome to Node-RED
11 Oct 14:34:48 - [info] Node-RED version: v1.0.1
11 Oct 14:34:48 - [info] Node.js version: v12.11.1
11 Oct 14:34:48 - [info] Darwin 18.7.0 x64 LE
11 Oct 14:34:48 - [info] Loading palette nodes
11 Oct 14:34:49 - [warn] ------------------------------------------------------
11 Oct 14:34:49 - [warn] [node-red-contrib-home-assistant-websocket/server] Type already registered
11 Oct 14:34:49 - [warn] [node-red-contrib-home-assistant-websocket/server-events] Type already registered
11 Oct 14:34:49 - [warn] [node-red-contrib-home-assistant-websocket/server-state-changed] Type already registered
11 Oct 14:34:49 - [warn] [node-red-contrib-home-assistant-websocket/trigger-state] Type already registered
11 Oct 14:34:49 - [warn] [node-red-contrib-home-assistant-websocket/poll-state] Type already registered
11 Oct 14:34:49 - [warn] [node-red-contrib-home-assistant-websocket/api-call-service] Type already registered
11 Oct 14:34:49 - [warn] [node-red-contrib-home-assistant-websocket/api-current-state] Type already registered
11 Oct 14:34:49 - [warn] [node-red-contrib-home-assistant-websocket/api-get-history] Type already registered
11 Oct 14:34:49 - [warn] [node-red-contrib-home-assistant-websocket/api-render-template] Type already registered
11 Oct 14:34:49 - [info] Settings file : /Users/robbertXXX/.node-red/settings.js
11 Oct 14:34:49 - [info] Context store : 'default' [module=memory]
11 Oct 14:34:49 - [info] User directory : /Users/robbertXXX/.node-red
11 Oct 14:34:49 - [warn] Projects disabled : editorTheme.projects.enabled=false
11 Oct 14:34:49 - [info] Flows file : /Users/robbertXXX/.node-red/flows_RobbertXXX.XXX.local.json
11 Oct 14:34:49 - [info] Creating new flow file
your credentials.
11 Oct 14:34:49 - [info] Starting flows
11 Oct 14:34:49 - [info] Started flows
11 Oct 14:34:49 - [info] Server now running at http://127.0.0.1:1880/
