No. That is not necessary & probably won't help.
- Rename
.node-redto.node-red-broken - Start node-red. - you should have a working, fresh/blank node-red
- install the nodes you need from palette
- Import your backup flow
.node-red to .node-red-brokenOh like that, so its a new installation
Not really, you are not re-installing node red, just starting with a new empty flow and default settings. Same as opening a word document with a blank page.
You could try setting the logging level in settings.js to trace. That might give useful info.
That's a helpful explanation, thank you. I got my flow running again BUT my main issue, which was the cause of this problem : is the UI table component. I am looking for a control to show whats in my database, something like a data table. Any suggestions ?
So that others can learn from your experience please tell us what you did to fix it.
If you mean the ui-table is causing problems then please tell us exactly in what way. That component is well tried and tested and very much used, so if there are any problems then I am sure the author will want to address them.
The ui-table widget is what you want for this.
So as per @Steve-Mcl advice I recovered my flow from the backup ".flow.JSON.backup" file after I started with a fresh instance of node-red, I simply imported it from the menu. So it was not a fix ,it was a role back to before I attempted the UI table that solved it.
Now on to the problem I was at when my node-red server got corrupted.
I want to show the values which were successfully saved in the database using the object that is returned from the DB node. What you see is the edit node of UI table.
You need to show us what you are sending to the table.
Expand the debug output so we can see what is in there. Click on Object to do that.
What does the help text for the ui-table say about what it needs to populate it?
when I click nothing comes up, it's just a text is shown in the debug window.
Edit the debug node and click the Output msg tab and select complete msg object
In that case I think that string is what is in the database. I think you had better look in the db to see what is there. Unless the db node passes the result in a different message property, which you will see following @zenofmud's suggestion.
That debug is showing you are doing an insert Not a select to retrieve data
What are you trying to show in the table? If you want to show all the data from the db then you will have to run an sql query to fetch it. If you are just trying to show the data that you are inserting then feed the ui-table with the data, not with the output of the db node.
My mistake, I assumed that when I saw the "object" it was confirming what was saved and that I could use the data to populate.
@Steve-Mcl @meeki007 can you guys help with this?
the ui-table will just accept an array by default... but13434 entries is probably a bit larger than is useful to try and display - so maybe your sql select could be changed to only return the latest 10-20 ?
Sure but, have you looked at my edit node, is the setup correct, is my style of referencing correctly to draw in the data. @dceejay
