This project is a Node-RED setup designed to run as part of the HA configuration on Elastic beanstalk with EFS. Node-RED shares state by using EFS for storage, which means all instances share the same flows, credentials etc. Configuration is passed in from the environment, so minimal config is kept within this filesystem.
Related topics
| Topic | Replies | Views | Activity | |
| Deploy to AWS with High Availability | 0 | 467 | 7 November 2019 | |
| Running Node-RED on AWS | 2 | 575 | 20 April 2023 | |
| Introducing node-red-cluster - a complete clustering solution for Node-RED (feedback and alternatives welcome) | 34 | 888 | 2 December 2025 | |
| AWS beanstalk - Lost connection to server | 3 | 1091 | 29 August 2019 | |
| Has anyone successfully deployed Node-RED on AWS Elastic Beanstalk on AL2023 (Amazon Linux 2023)? If so, what was your process? | 1 | 67 | 18 May 2025 |
