Node red foreach error
Please help! I was busy with creating a ui with a table and text fields when all of a sudden my node red close and I got this error in command prompt. I thought the problem was in my flow so I copied my flow file out and completely removed node red and uninstalled node.js. I made sure everything was removed, restarted my pc and started installing everything again but still got the error. I am rather new to node red so all my I am still training. The error is below:
[error] TypeError: Cannot read property 'forEach' of undefined
    at Object.addModule (C:\Users\Manie\AppData\Roaming\npm\node_modules\node-red\node_modules\@node-red\registry\lib\registry.js:186:27)
    at C:\Users\Manie\AppData\Roaming\npm\node_modules\node-red\node_modules\@node-red\registry\lib\loader.js:108:30
    at tryCatchReject (C:\Users\Manie\AppData\Roaming\npm\node_modules\node-red\node_modules\when\lib\makePromise.js:845:30)
    at runContinuation1 (C:\Users\Manie\AppData\Roaming\npm\node_modules\node-red\node_modules\when\lib\makePromise.js:804:4)
    at Fulfilled.when (C:\Users\Manie\AppData\Roaming\npm\node_modules\node-red\node_modules\when\lib\makePromise.js:592:4)
    at Pending.run (C:\Users\Manie\AppData\Roaming\npm\node_modules\node-red\node_modules\when\lib\makePromise.js:483:13)
    at Scheduler._drain (C:\Users\Manie\AppData\Roaming\npm\node_modules\node-red\node_modules\when\lib\Scheduler.js:62:19)
    at Scheduler.drain (C:\Users\Manie\AppData\Roaming\npm\node_modules\node-red\node_modules\when\lib\Scheduler.js:27:9)
    at processTicksAndRejections (node:internal/process/task_queues:76:11
That error is caused by having a badly written node installed. Have you installed any new nodes recently, or perhaps tried developing your own?
No, no new nodes and yes have been developing after having a short crash course to get me going. I had a table with some text fields and I was busy sorting them the way I wanted when this happened the first time.
start node-red with 'node-red --safe' and see if you startup with out a problem.
If you do, disable the node you were playing wth and deploy and see if that prevents the issue. That will at least narrow down the cause.
Also, could you attach your flow to a reply? In order to make code more readable and importable it is important to surround your code with three backticks
```like this```
You can edit and correct your post by clicking the pencil icon.
Below is my flow code.
[{"id":"cf8dbb6c.418578","type":"tab","label":"SQL Data","disabled":false,"info":""},{"id":"adcc8ab.53ef578","type":"tab","label":"Persons","disabled":false,"info":""},{"id":"2df6556d.91840a","type":"MSSQL-CN","name":"AddressBook MSSQL","server":"127.0.0.1","encyption":true,"database":"MWT-AddressBook-Test"},{"id":"8dd33c30.79f7c","type":"ui_base","theme":{"name":"theme-light","lightTheme":{"default":"#0094CE","baseColor":"#0096cc","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":true,"reset":false},"darkTheme":{"default":"#097479","baseColor":"#097479","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif","edited":false},"customTheme":{"name":"Untitled Theme 1","default":"#4B7930","baseColor":"#4B7930","baseFont":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"},"themeState":{"base-color":{"default":"#0094CE","value":"#0096cc","edited":true},"page-titlebar-backgroundColor":{"value":"#0096cc","edited":false},"page-backgroundColor":{"value":"#fafafa","edited":false},"page-sidebar-backgroundColor":{"value":"#ffffff","edited":false},"group-textColor":{"value":"#1ac2ff","edited":false},"group-borderColor":{"value":"#ffffff","edited":false},"group-backgroundColor":{"value":"#ffffff","edited":false},"widget-textColor":{"value":"#111111","edited":false},"widget-backgroundColor":{"value":"#0096cc","edited":false},"widget-borderColor":{"value":"#ffffff","edited":false},"base-font":{"value":"-apple-system,BlinkMacSystemFont,Segoe UI,Roboto,Oxygen-Sans,Ubuntu,Cantarell,Helvetica Neue,sans-serif"}},"angularTheme":{"primary":"indigo","accents":"blue","warn":"red","background":"grey"}},"site":{"name":"Node-RED Dashboard","hideToolbar":"false","allowSwipe":"false","lockMenu":"false","allowTempTheme":"true","dateFormat":"DD/MM/YYYY","sizes":{"sx":48,"sy":48,"gx":6,"gy":6,"cx":6,"cy":6,"px":0,"py":0}}},{"id":"85b2f0aa.9f15","type":"ui_tab","name":"Input Address","icon":"dashboard","order":1,"disabled":false,"hidden":false},{"id":"213511c9.74f04e","type":"ui_group","name":"Persons Inputs","tab":"85b2f0aa.9f15","order":1,"disp":true,"width":"30","collapse":false},{"id":"aa16b199.90224","type":"ui_spacer","name":"spacer","group":"213511c9.74f04e","order":5,"width":7,"height":1},{"id":"ebff0c21.5146","type":"ui_spacer","name":"spacer","group":"213511c9.74f04e","order":8,"width":7,"height":1},{"id":"86a99f8e.f95c5","type":"ui_spacer","name":"spacer","group":"213511c9.74f04e","order":11,"width":7,"height":1},{"id":"952afff1.638aa","type":"ui_spacer","name":"spacer","group":"213511c9.74f04e","order":14,"width":7,"height":1},{"id":"679248e8.bab098","type":"ui_spacer","name":"spacer","group":"213511c9.74f04e","order":17,"width":7,"height":1},{"id":"2a33ebb1.ec17e4","type":"ui_spacer","name":"spacer","group":"213511c9.74f04e","order":20,"width":7,"height":1},{"id":"173e5cb6.287403","type":"ui_spacer","name":"spacer","group":"213511c9.74f04e","order":23,"width":7,"height":1},{"id":"be97ff07.7615","type":"ui_spacer","name":"spacer","group":"213511c9.74f04e","order":26,"width":7,"height":1},{"id":"cf9554b.944aaa8","type":"ui_spacer","name":"spacer","group":"213511c9.74f04e","order":29,"width":7,"height":1},{"id":"2194f328.d26bbc","type":"ui_spacer","name":"spacer","group":"213511c9.74f04e","order":32,"width":7,"height":1},{"id":"cef3e971.5b7bf8","type":"ui_spacer","name":"spacer","group":"","order":1,"width":1,"height":1},{"id":"9b755ae6.fc5938","type":"ui_group","name":"Person List","tab":"85b2f0aa.9f15","order":2,"disp":true,"width":"27","collapse":true},{"id":"3dbc29f7.b1e346","type":"ui_spacer","name":"spacer","group":"213511c9.74f04e","order":1,"width":1,"height":1},{"id":"ff60d02b.4c431","type":"inject","z":"cf8dbb6c.418578","name":"GetData","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":80,"y":40,"wires":[["f66a04f0.ade328"]]},{"id":"b0e5a7d9.93ae58","type":"MSSQL","z":"cf8dbb6c.418578","mssqlCN":"2df6556d.91840a","name":"AddressBook MSSQL","query":"SELECT * FROM tbl_Person","outField":"payload","x":480,"y":40,"wires":[["4809a6ee.efd348","2768613a.477ffe"]]},{"id":"4809a6ee.efd348","type":"debug","z":"cf8dbb6c.418578","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":810,"y":60,"wires":[]},{"id":"157f52f1.97a60d","type":"http in","z":"cf8dbb6c.418578","name":"Read","url":"/addresses","method":"get","upload":false,"swaggerDoc":"","x":70,"y":100,"wires":[["f66a04f0.ade328"]]},{"id":"f66a04f0.ade328","type":"template","z":"cf8dbb6c.418578","name":"List Addresses","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<!DOCTYPE html>\n<html>\n    <head>\n        <link href=\"https://cdnjs.cloudflare.com/ajax/libs/bootswatch/4.5.3/slate/bootstrap.min.css\" rel=\"stylesheet\"/>\n    </head>\n<body>\n\n<h1 align=\"center\">Addresses</h1>\n<table style=\"width:100%\">\n  <tr>\n    <th>Firstname</th>\n    <th>Lastname</th>\n    <th>Age</th>\n  </tr>\n  <tr>\n    <td>Jill</td>\n    <td>Smith</td>\n    <td>50</td>\n  </tr>\n  <tr>\n    <td>Eve</td>\n    <td>Jackson</td>\n    <td>94</td>\n  </tr>\n</table>\n\n</body>\n</html>","output":"str","x":260,"y":40,"wires":[["b0e5a7d9.93ae58"]]},{"id":"2768613a.477ffe","type":"http response","z":"cf8dbb6c.418578","name":"","statusCode":"","headers":{},"x":740,"y":120,"wires":[]},{"id":"c536a609.7eb078","type":"ui_text_input","z":"adcc8ab.53ef578","name":"First_Name","label":"","tooltip":"","group":"213511c9.74f04e","order":4,"width":6,"height":1,"passthru":false,"mode":"text","delay":"0","topic":"First_Name","x":1250,"y":60,"wires":[[]]},{"id":"3b7d0431.f5261c","type":"MSSQL","z":"adcc8ab.53ef578","mssqlCN":"2df6556d.91840a","name":"Select","query":"","outField":"payload","x":350,"y":80,"wires":[["93e51649.f82748","6388fb6.61c5704","da3793b7.fe5b3","4c59f987.1dc928","6a5bca4.0447334","77e669b.fc8f198","1b7918d9.5365e7","86289b76.5dd518","4b0a8c23.e1e364","dcb44cc5.08259","9415b77b.981e28","96b4185.ab580e8"]]},{"id":"1f37bc02.c14b44","type":"ui_text_input","z":"adcc8ab.53ef578","name":"Last_Name","label":"","tooltip":"","group":"213511c9.74f04e","order":7,"width":6,"height":1,"passthru":false,"mode":"text","delay":"300","topic":"Last_Name","x":1250,"y":140,"wires":[[]]},{"id":"de374fcd.3e06a","type":"inject","z":"adcc8ab.53ef578","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"num","x":70,"y":80,"wires":[["4dadc75c.77bd08"]]},{"id":"de759d1d.1e31e","type":"ui_text_input","z":"adcc8ab.53ef578","name":"Address1","label":"","tooltip":"","group":"213511c9.74f04e","order":10,"width":6,"height":1,"passthru":false,"mode":"text","delay":"0","topic":"Address1","x":1240,"y":220,"wires":[[]]},{"id":"64f060f6.eece9","type":"ui_text_input","z":"adcc8ab.53ef578","name":"Address2","label":"","tooltip":"","group":"213511c9.74f04e","order":13,"width":6,"height":1,"passthru":false,"mode":"text","delay":"0","topic":"Address2","x":1240,"y":300,"wires":[[]]},{"id":"2d4f7da6.f08ca2","type":"ui_text_input","z":"adcc8ab.53ef578","name":"Address3","label":"","tooltip":"","group":"213511c9.74f04e","order":16,"width":6,"height":1,"passthru":false,"mode":"text","delay":"0","topic":"Address3","x":1240,"y":380,"wires":[[]]},{"id":"4f9f4678.01e4b8","type":"ui_text_input","z":"adcc8ab.53ef578","name":"Address4","label":"","tooltip":"","group":"213511c9.74f04e","order":19,"width":6,"height":1,"passthru":false,"mode":"text","delay":"0","topic":"Address4","x":1240,"y":460,"wires":[[]]},{"id":"f1653c05.86148","type":"ui_text_input","z":"adcc8ab.53ef578","name":"Postal_Code","label":"","tooltip":"","group":"213511c9.74f04e","order":25,"width":6,"height":1,"passthru":false,"mode":"text","delay":"0","topic":"Postal_Code","x":1250,"y":540,"wires":[[]]},{"id":"ca366145.3f6f1","type":"ui_text_input","z":"adcc8ab.53ef578","name":"Home_Tel","label":"","tooltip":"","group":"213511c9.74f04e","order":22,"width":6,"height":1,"passthru":true,"mode":"text","delay":300,"topic":"Home_Tel","x":1240,"y":620,"wires":[[]]},{"id":"9c06546e.572848","type":"ui_text_input","z":"adcc8ab.53ef578","name":"Work_Tel","label":"","tooltip":"","group":"213511c9.74f04e","order":28,"width":6,"height":1,"passthru":false,"mode":"text","delay":"0","topic":"Work_Tel","x":1240,"y":700,"wires":[[]]},{"id":"fecf3304.cd918","type":"ui_text_input","z":"adcc8ab.53ef578","name":"CellPhone","label":"","tooltip":"","group":"213511c9.74f04e","order":31,"width":6,"height":1,"passthru":false,"mode":"text","delay":"0","topic":"CellPhone","x":1250,"y":780,"wires":[[]]},{"id":"5d434bc7.9677e4","type":"ui_text_input","z":"adcc8ab.53ef578","name":"EMail","label":"","tooltip":"","group":"213511c9.74f04e","order":34,"width":6,"height":1,"passthru":true,"mode":"text","delay":300,"topic":"EMail","x":1230,"y":860,"wires":[[]]},{"id":"4e2f1a00.e47824","type":"debug","z":"adcc8ab.53ef578","name":"Debug Select","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":380,"y":40,"wires":[]},{"id":"4dadc75c.77bd08","type":"function","z":"adcc8ab.53ef578","name":"Select","func":"var Person_ID = 1;\n\nmsg.payload = `SELECT Person_ID\n     , First_Name\n     , Last_Name\n     , Address1\n     , Address2\n     , Address3\n     , Address4\n     , Postal_Code\n     , Home_Tel\n     , Work_Tel\n     , CellPhone\n     , EMail\nFROM dbo.tbl_Person \nWHERE Person_ID = `  + Person_ID;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":210,"y":80,"wires":[["3b7d0431.f5261c","4e2f1a00.e47824"]]},{"id":"93e51649.f82748","type":"function","z":"adcc8ab.53ef578","name":"","func":"node.send({\"payload\" : msg.payload[0].First_Name});\n//return msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":860,"y":80,"wires":[["c536a609.7eb078","769c4be6.c77014"]]},{"id":"6388fb6.61c5704","type":"function","z":"adcc8ab.53ef578","name":"","func":"node.send({\"payload\" : msg.payload[0].Last_Name});\n//return x;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":860,"y":140,"wires":[["1f37bc02.c14b44","aab957be.5a89a8"]]},{"id":"9415b77b.981e28","type":"function","z":"adcc8ab.53ef578","name":"","func":"node.send({\"payload\" : msg.payload[0].Address2});","outputs":1,"noerr":0,"initialize":"","finalize":"","x":860,"y":260,"wires":[["64f060f6.eece9","d118cd2b.662f5"]]},{"id":"1b7918d9.5365e7","type":"function","z":"adcc8ab.53ef578","name":"","func":"node.send({\"payload\" : msg.payload[0].Home_Tel});","outputs":1,"noerr":0,"initialize":"","finalize":"","x":860,"y":500,"wires":[["ca366145.3f6f1","3dbcbb5b.11ad84"]]},{"id":"4c59f987.1dc928","type":"function","z":"adcc8ab.53ef578","name":"","func":"node.send({\"payload\" : msg.payload[0].Address3});","outputs":1,"noerr":0,"initialize":"","finalize":"","x":860,"y":320,"wires":[["2d4f7da6.f08ca2","4cd63b12.6faf24"]]},{"id":"6a5bca4.0447334","type":"function","z":"adcc8ab.53ef578","name":"","func":"node.send({\"payload\" : msg.payload[0].Address4});","outputs":1,"noerr":0,"initialize":"","finalize":"","x":860,"y":380,"wires":[["4f9f4678.01e4b8","c9ab2287.ecc13"]]},{"id":"77e669b.fc8f198","type":"function","z":"adcc8ab.53ef578","name":"","func":"node.send({\"payload\" : msg.payload[0].Postal_Code});","outputs":1,"noerr":0,"initialize":"","finalize":"","x":860,"y":440,"wires":[["f1653c05.86148","e82f8b9c.8936c8"]]},{"id":"da3793b7.fe5b3","type":"function","z":"adcc8ab.53ef578","name":"","func":"node.send({\"payload\" : msg.payload[0].Address1});\n//return x;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":860,"y":200,"wires":[["de759d1d.1e31e","1beef832.d2fb78"]]},{"id":"dcb44cc5.08259","type":"function","z":"adcc8ab.53ef578","name":"","func":"node.send({\"payload\" : msg.payload[0].Work_Tel});","outputs":1,"noerr":0,"initialize":"","finalize":"","x":860,"y":560,"wires":[["9c06546e.572848","5391e8b.e184c18"]]},{"id":"86289b76.5dd518","type":"function","z":"adcc8ab.53ef578","name":"","func":"node.send({\"payload\" : msg.payload[0].CellPhone});","outputs":1,"noerr":0,"initialize":"","finalize":"","x":860,"y":620,"wires":[["fecf3304.cd918","cc9e7343.1e035"]]},{"id":"4b0a8c23.e1e364","type":"function","z":"adcc8ab.53ef578","name":"","func":"node.send({\"payload\" : msg.payload[0].EMail});","outputs":1,"noerr":0,"initialize":"","finalize":"","x":860,"y":680,"wires":[["5d434bc7.9677e4","f4ec8e43.9c8bd"]]},{"id":"96b4185.ab580e8","type":"ui_table","z":"adcc8ab.53ef578","group":"9b755ae6.fc5938","name":"","order":1,"width":"27","height":11,"columns":[],"outputs":0,"cts":false,"x":410,"y":220,"wires":[]},{"id":"b1308de2.99935","type":"function","z":"adcc8ab.53ef578","name":"Select","func":"\n\n\nmsg.payload = `SELECT Person_ID\n     , First_Name\n     , Last_Name\n     , Address1\n     , Address2\n     , Address3\n     , Address4\n     , Postal_Code\n     , Home_Tel\n     , Work_Tel\n     , CellPhone\n     , EMail\nFROM dbo.tbl_Person`;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":210,"y":140,"wires":[["3b7d0431.f5261c"]]},{"id":"3e2cf0cf.24cd9","type":"inject","z":"adcc8ab.53ef578","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1","payloadType":"num","x":70,"y":140,"wires":[["b1308de2.99935"]]},{"id":"769c4be6.c77014","type":"ui_text","z":"adcc8ab.53ef578","group":"213511c9.74f04e","order":3,"width":4,"height":1,"name":"FirstName","label":"First Name","format":"","layout":"row-right","x":1250,"y":20,"wires":[]},{"id":"aab957be.5a89a8","type":"ui_text","z":"adcc8ab.53ef578","group":"213511c9.74f04e","order":6,"width":4,"height":1,"name":"LastName","label":"Last Name","format":"","layout":"row-right","x":1250,"y":100,"wires":[]},{"id":"1beef832.d2fb78","type":"ui_text","z":"adcc8ab.53ef578","group":"213511c9.74f04e","order":9,"width":4,"height":1,"name":"Address1","label":"Address 1","format":"","layout":"row-right","x":1240,"y":180,"wires":[]},{"id":"d118cd2b.662f5","type":"ui_text","z":"adcc8ab.53ef578","group":"213511c9.74f04e","order":12,"width":4,"height":1,"name":"Address2","label":"Address 2","format":"","layout":"row-right","x":1240,"y":260,"wires":[]},{"id":"4cd63b12.6faf24","type":"ui_text","z":"adcc8ab.53ef578","group":"213511c9.74f04e","order":15,"width":4,"height":1,"name":"Address3","label":"Address 3","format":"","layout":"row-right","x":1240,"y":340,"wires":[]},{"id":"c9ab2287.ecc13","type":"ui_text","z":"adcc8ab.53ef578","group":"213511c9.74f04e","order":18,"width":4,"height":1,"name":"Address4","label":"Address 4","format":"","layout":"row-right","x":1240,"y":420,"wires":[]},{"id":"e82f8b9c.8936c8","type":"ui_text","z":"adcc8ab.53ef578","group":"213511c9.74f04e","order":21,"width":4,"height":1,"name":"PostalCode","label":"Postal Code","format":"","layout":"row-right","x":1250,"y":500,"wires":[]},{"id":"3dbcbb5b.11ad84","type":"ui_text","z":"adcc8ab.53ef578","group":"213511c9.74f04e","order":24,"width":4,"height":1,"name":"HomeTel","label":"Home Tel","format":"","layout":"row-right","x":1240,"y":580,"wires":[]},{"id":"5391e8b.e184c18","type":"ui_text","z":"adcc8ab.53ef578","group":"213511c9.74f04e","order":27,"width":4,"height":1,"name":"WorkTel","label":"Work Tel","format":"","layout":"row-right","x":1240,"y":660,"wires":[]},{"id":"cc9e7343.1e035","type":"ui_text","z":"adcc8ab.53ef578","group":"213511c9.74f04e","order":30,"width":4,"height":1,"name":"CellPhone","label":"Cell Phone","format":"","layout":"row-right","x":1250,"y":740,"wires":[]},{"id":"f4ec8e43.9c8bd","type":"ui_text","z":"adcc8ab.53ef578","group":"213511c9.74f04e","order":33,"width":4,"height":1,"name":"EMail","label":"E-Mail","format":"","layout":"row-right","x":1230,"y":820,"wires":[]}]
