Hi ,
I 'm using nora for the google home integration for the flows in node red . Every time I deploy any new flow , I keep getting this message .
Anyone know how we can get more details on this .
msg : string[49]
"nora (9qOHU): disconnected (io client disconnect)"
Thanks!
Hi I suspect the (Google) node you are using uses an external service called Nora.
2ndly, I suspect you are doing full deploy.
Full deploy stops all nodes and flows - hence my 1st suspicion.
If you were just curious- problem solved.
If you were already aware of the Nora thing but are trying to prevent it disconnecting - don't so a full deploy.
Great, thanks for the response .
Yes, I was doing a full deploy . I changed the setting to only modified now and the message doesn't appear .
