Hey,
If the two switches are off and then I trigger one of the injectors, the function behind it is still executed, but why?
Why is this still happening?
Thanks in advance
Hey,
Thanks in advance
It's still happening because you misunderstand the role of a ui-switch.
For a node which either blocks messages or lets them through, try node-red-contrib-simple-gate
Thank you.
I thought the switch blocks messages.
I put a function behind the Switch with this code:
if(msg.payload == true)
Now its working
I'm glad you have fixed it.
At the risk of confusing you, there is also a Switch node (not UI) which can very easily discard or divert messages based on their payload.
It's probably a mistake to jump too quickly into writing functions rather than using the available nodes.
