Node-red in docker container - apt command not found
I have node-red installed on my docker server running on ubuntu 21.10:
docker run -it -p 1880:1880 -v node_red_data:/data --name mynodered nodered/node-red
And wanted to install the imagemagick software in the same container but just discovered that the apt command is missing:
lab@docker:~$ sudo docker exec -it nodered bash
bash-5.0$ apt update
bash: apt: command not found
bash-5.0$
Can you help ?
Is it possible to have the apt command available?
The official node-red docker image runs on alpine : Running under Docker : Node-RED
Alpine uses apk instead of apt
This might help: ImageMagick installation in Docker Alpine - Stack Overflow
If you customise the image, sure.
