Node-RED in your browser with unkernel
Hi everyone,
I recently tried unkernel, which runs Linux in the browser using WebAssembly. The shell felt surprisingly responsive, so I wondered if it could run Node-RED too.
I tried it with some help from Codex and put the result on GitHub Pages. Open the demo and give it a minute or two to boot. You’ll get an empty Node-RED editor running in your browser, with no server to set up. A simple Inject → Debug flow is a good first thing to try.
Try the demo · GitHub repository
The Linux guest runs offline, so HTTP Request nodes can’t reach external services. HTTP In endpoints aren’t accessible from outside the demo, so it can’t receive webhooks or host a public API. Reloading resets the session, so export any flows you want to keep.
This is an experimental demo provided as-is. It runs within GitHub Pages’ free usage limits, and I may take it down if hosting issues come up.
If you try it, I’d love to hear what worked for you and where you ran into limits.
Looked like fun to play with but with no network access there's not much I could think to do with it :frowning:
Nice work!
I would use it if I was a chrome user: "Startup failed. This engine has no JSPI (WebAssembly.Suspending / WebAssembly.promising), which the kernel needs"
I get that on my Firefox and Safari and I don't use chrome :frowning:
A couple of years ago, I did something similar with a pure JS version using NR v3, so it's a bit long in the tooth --> https://cdn.flowhub.org/ - it also just runs in the browser and simulates some of the core nodes but it was never intended to be 100% in-browser NR version, rather just to give folks a feeling of NR without installing NR. Codebase for the project (also a github page).
It's good intuitive and I hope you continue with it because having good ways of showing folks node red without them having to install anything is great for the project (and for the idea of general visual programming).
There seem to be a few projects that will run node.js in the browser.
WebContainers (StackBlitz), almostnode, Nodebox (CodeSandbox)
Maybe a few others that I missed. Not sure if any will run Node-RED.
Thanks for sharing the FlowHub project! I’d come across it before. What intrigued me about unkernel was the idea of running Node-RED itself inside a Linux instance in the browser. I wanted to see whether I could use the usual editor and runtime to build and test flows, and whether it would feel fast enough to work with. In my testing, once Node-RED had started, editing and deploying flows felt responsive enough to actually use.
A quick update on networking, too: with a Wisp relay configured, I was able to install FlowFuse Dashboard from the Palette Manager, open it in another tab, and watch it update live as I sent messages from a flow. That was the point where it started to feel like a Node-RED environment I could experiment in.
I’ve tested the setup with a Wisp relay and plan to share the steps so others can try it too.
A quick update: I’ve added Wisp relay setup instructions to the README. They show how to run a relay on the same machine as your browser and pass its address to the demo with ?wisp=. This lets Node-RED call external APIs and install nodes through the Palette Manager.
I’ve also updated the browser requirements to explain which browser versions support WebAssembly JSPI, which unkernel needs to start. I’ve tested the demo on Windows with Chrome 158, Edge 156, and Firefox 161.
Thanks for that and reminds me to update my firefox! :wink: I was using an older version and hence it didn't work.
A quick follow-up: I’ve added Backup and Restore buttons to the browser demo. Backup saves your deployed flows, Node-RED settings, and installed custom nodes as a .tar.gz file on the machine running your browser. The next time you open the demo, click Restore and select that file. The guest restarts in the same tab with your saved setup.
This makes it easier to experiment with add-ons like FlowFuse Dashboard 2. You can install it once, back up your setup, and pick up where you left off without waiting for npm to install it again.
Try the demo
Backup and restore instructions
