Node-red library update issue
ehostunreach 104.16.23.35:443 on raspberry pi when I try to update node-red library
Command: npm install node-red-contrib-interval-length
Not a node-red issue, network issue.
Who is 104.16.23.35 ?
I have resolved the network issue. But now it returns ENOENT error
You state:
I try to update
and you use
That is not updating, but installing.
Where are you installing this ? In which directory are you located ? You need to be in the .node-red directory.
Go to the node-red editor, right top:
hamburger menu -> manage palette.
Click install tab.
Search 'node-red-contrib-interval-length'
Install.
Thanks, it's resolved
The reason it did not work when you used the command line was because you had not changed to the .node-red directory first.
