Good day
I am using node-red-node-snmp to connect from a site to my site. At the outgoing site, the port is released for my IP via Fortigate. Unfortunately, I cannot enter an IP range there. However, this location has several servers. Now my question is, is it possible to adjust the port in the node-red-node-snmp so that I can make a port forwarde at the firewall with a different outgoing port which then redirects to 161, such as 8161 or so?
Thank you for your help.
