Hello
would be nice if you could define a SNMP Host, only ones (IP and Hostname ro value) so you don't have to add the ip address on many differen requests.
have a nice day
vinc
Hello
have a nice day
vinc
You can also report this feature request as an issue on the node’s github repository.
Hi - not sure quite what you mean... You can either set it in the node - or if you leave it blank then you pass it in as msg.host. You can also specify it as an environment variable from outside Node-RED if you wish, using ${my_env_variable} syntax. What other other option are you looking for ?
