Dynamic host IP in "snmp subtree" node?
I have multiple "snmp subtree" nodes reading data from a network switch.
This means if the IP address I have to edit several nodes.
Is it possible to set the IP address e.g. in a variable which I can use within the "snmp subtree" node in the field "Host"?
Read the built
Did you read the built in help?
It says you can send this in msg.host
Oh, shame on me :woozy_face:
Thank you!
