Node-RED Projects: using an organization's Github repository with SSH
Hello!
I am wondering if anyone has tied Node-RED to an organization repo over SSH before, because I am having some trouble. Is it possible? I have setup a Github remote over SSH to a personal repo before without issue.
Here is what I have tried:
I am part of an organization that has a repository with flows.json, credentials.json, package.json
I generated an SSH key through the Node-RED projects settings: ssh-rsa AAAAB3NzaC1yc2EAAA... (etc)
I added the public key to the organization's Github repository as a Deploy key (note: during troubleshooting I have also tried adding it to my personal account's SSH keys)
Now I am trying to clone the project over SSH using the Github projects "New Project" template. This is what I have for each step:
Username: using my personal account username
Email: using my github account email
Project name: using same as the repo (for simplicity)
Git repository url: ssh://git@github.com:[my organization]/[repo name].git
SSH Key: the key I generated shows up so I select it
Passphrase: none for now (when I figure out how this works I can make a new key)
When I try to follow through with this, I get "Authentication failed"
The chance that I am doing something wrong is non-zero (high), but I also realize there may not be support for cloning from organization repos using deploy keys.
I think I fixed my own problem. I may leave this post up for anyone else who runs into similar issues.
If you look at the SSH URL I was trying, I had:
That URL is based on the one Github provides when selecting "SSH" as a cloning method.
The issue is the colon : between github and my organization. The proper URL should be:
ssh://git@github.com/[my organization]/[repo name]
