"This service is not implemented on the module or a frame error was reported" can anyone tell me what error is this?
Hi VicK.
Probably you'll have to give us a bit more detail.
- Where do you see that error?
- What were you trying to do which resulted in the error?
- What version of Node-red are you using?
- Where and how did you install it?
- Have you ever had it running successfully?
Welcome to the forum @VicK
Is this an S7 comms issue?
Please tell us more about your system.
What hardware
What OS
What version of node-red (Visible at bottom of the drop down menu in node red)
What version of nodejs (Run node -v in a terminal to find out)
What s7 node are you using (node-red-contrib-??? possibly) and what version of it.
How did you install node-red?
that just download problem in s71200 i missed out the to download the hardware in topology.
After the found it and cleared it.
Thanks jbudd
That was just download problem in s71200 I forget to missed out the to download the hardware in topology.
BTW Thanks Colin
