Node red update
I planning to update from v0.17.5 to v1.1.3. I have flows using installed nodes. Grateful if someone can share procedure to migrate and have my flows up and running
What is your operating system & what hardware is it running on?
Thanks for your support
I have two casesIn a rsberry 4 with rasbian
And PC with windows 10
Have you look at this doc ? :
Hi
I reviewed the documents you recommended and following the instructions I made the update without problems.
I Appreciate your support
thanks you so much
For the Raspberry NR update, i made a "auto"update Here.
Enjoy
