I am using node-red on Windows 10. When I check the installed packages in "Manage palette" this is displayed for node-red itself:
node-red
0.19.4
- Not currently supported on Windows.
- Error: Cannot find module 'sqlite3' (line:23)
If I execute the command "npm info node-red version" from the power shell console, the following is displayed:
0.19.5
When starting node-red, following messages are displayed:
Welcome to Node-RED
22 Feb 07:32:25 - [info] Node-RED version: v0.19.4
22 Feb 07:32:25 - [info] Node.js version: v8.12.0
22 Feb 07:32:25 - [info] Windows_NT 10.0.17134 x64 LE
22 Feb 07:32:27 - [info] Loading palette nodes
22 Feb 07:32:30 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
22 Feb 07:32:46 - [info] Dashboard version 2.13.2 started at /ui
22 Feb 07:32:55 - [warn] ------------------------------------------------------
22 Feb 07:32:55 - [warn] [node-red/tail] Not currently supported on Windows.
22 Feb 07:32:55 - [warn] [node-red/litedb] Error: Cannot find module 'sqlite3' (line:23)
22 Feb 07:32:55 - [info] Settings file : \Users*.node-red\settings.js
22 Feb 07:32:55 - [info] HTTP Static : C:\Users*.node-red\public
22 Feb 07:32:55 - [info] Context store : 'default' [module=memory]
22 Feb 07:32:55 - [info] User directory : \Users*.node-red
22 Feb 07:32:55 - [warn] Projects disabled : editorTheme.projects.enabled=false
22 Feb 07:32:55 - [info] Flows file : \Users*.node-red\flows_***.json
22 Feb 07:32:55 - [info] Server now running at http://127.0.0.1:1880/
Why is not used the latest node-red version (0.19.5)?
