Node-Red is Installed with all defaults.
Normal operation until "projects" is enabled.
Then when starting I get:
Graph showing "Loading Nodes 1/59 that stops at 59/59"
Error: Failed to load ‘node-red/comment’
Normal operation resumes after disabling "projects" and restarting node-red.
Node-RED version: v1.2.7
Node.js version: v14.15.3
Dashboard version 2.26.1 started at /ui
Windows_NT 10.0.18363 x64 LE
Win10 pro v1909 6700K w/ 32 GB Ram
Firefox, Chrome and Edge give identical results.
Have uninstalled and reinstalled node-red using Power Shell w/ Admin - forced all new default directories
With a new node-red install and projects enabled:
PS C:\Windows\system32> node-red
8 Jan 21:29:03 - [info]
Welcome to Node-RED
8 Jan 21:29:03 - [info] Node-RED version: v1.2.7
8 Jan 21:29:03 - [info] Node.js version: v14.15.3
8 Jan 21:29:03 - [info] Windows_NT 10.0.18363 x64 LE
8 Jan 21:29:04 - [info] Loading palette nodes
8 Jan 21:29:05 - [info] Dashboard version 2.26.1 started at /ui
8 Jan 21:29:05 - [info] Settings file : C:\Users\FLA.node-red\settings.js
8 Jan 21:29:05 - [info] Context store : 'default' [module=memory]
8 Jan 21:29:05 - [info] User directory : \Users\FLA.node-red
8 Jan 21:29:05 - [warn] No active project : using default flows file
8 Jan 21:29:05 - [info] Flows file : \Users\FLA.node-red\flows_FLA.json
8 Jan 21:29:05 - [info] Server now running at http://127.0.0.1:1880/
8 Jan 21:29:05 - [info] Starting flows
8 Jan 21:29:05 - [info] Started flows
8 Jan 21:29:05 - [info] [udp in:f2742f39.0019b8] udp listener at 0.0.0.0:4992
8 Jan 21:31:29 - [info] Stopping flows
8 Jan 21:31:29 - [info] [udp in:f2742f39.0019b8] udp listener stopped
8 Jan 21:31:29 - [info] Stopped flows
8 Jan 21:31:29 - [info] Starting flows
8 Jan 21:31:29 - [info] Started flows
8 Jan 21:31:29 - [info] [udp in:f2742f39.0019b8] udp listener at 0.0.0.0:4992
8 Jan 22:33:32 - [info] Stopping flows
8 Jan 22:33:32 - [info] [udp in:f2742f39.0019b8] udp listener stopped
8 Jan 22:33:32 - [info] Stopped flows
8 Jan 22:33:38 - [info]
With projects disabled:
Welcome to Node-RED
8 Jan 22:33:38 - [info] Node-RED version: v1.2.7
8 Jan 22:33:38 - [info] Node.js version: v14.15.3
8 Jan 22:33:38 - [info] Windows_NT 10.0.18363 x64 LE
8 Jan 22:33:39 - [info] Loading palette nodes
8 Jan 22:33:39 - [info] Dashboard version 2.26.1 started at /ui
8 Jan 22:33:39 - [info] Settings file : C:\Users\FLA.node-red\settings.js
8 Jan 22:33:39 - [info] Context store : 'default' [module=memory]
8 Jan 22:33:39 - [info] User directory : \Users\FLA.node-red
8 Jan 22:33:39 - [warn] Projects disabled : editorTheme.projects.enabled=false
8 Jan 22:33:39 - [info] Flows file : \Users\FLA.node-red\flows_FLA.json
8 Jan 22:33:39 - [info] Server now running at http://127.0.0.1:1880/
8 Jan 22:33:39 - [info] Starting flows
8 Jan 22:33:39 - [info] Started flows
8 Jan 22:33:39 - [info] [udp in:f2742f39.0019b8] udp listener at 0.0.0.0:4992
Thanks for any trouble-shooting suggestions as I am very new to this!
