Node-red x plc s7 1200
Node-RED v4.0.2
node.js v20.9.0
nó s7 plc siemens
I'm using node-red as a client and s7 1200 as a server, when I press the physical button of the I0.0 input I call an endpoint to do a task but when I release my I0.0 button again it calls my endpoint again, could it help to solve the end point call only by pressing the button?
Hi @AdrianoOPereira
I know zero/nada/none/null about PLC
I don't truly understand the setup - but if the endpoint you're referring to is inside Node RED,
you can use the delay Node in rate limit mode ?
Say only allow messages to pass after 2-5s of each other?
I apologies, if I have got this completely wrong
Or maybe use a Switch node to only pass messages with payload of the press event.
If you can't work it out, feed what you are getting into a debug node and show us what you get for the two events.
