Node-Red's Website - flows page
The flows page does not render my entire README.md file
https://flows.nodered.org/node/node-red-contrib-facial-recognition
it shows fine on:
NPM https://www.npmjs.com/package/node-red-contrib-facial-recognition
Github https://github.com/meeki007/node-red-contrib-facial-recognition
This is a low priority for me. Just thought someone should know.
You've mixed HTML and Markdown. Looks like even GitHub doesn't like it as the code doesn't render correctly.
That is also a very long README. You might want to create a docs folder and split it up.
Will try that now
The issue is the length of the readme.
We use the readme provided by the npm api - http://registry.npmjs.org/node-red-contrib-facial-recognition - rather than the actual file contents. In this instance, due to the length, it is being truncated in the api response.
I would suggest, as a minimum, moving the example flows out to their own files and linking to them.
Its fixed. Thanks for the suggestions
