Node UI Not Response
When I deployed an extremely simple page, the UI appears as follows.
I'm trying to work on Rasbperry Pi
resim
Did you add dashboard nodes ? Did you configure them correctly ?
Just add a button and try to see it on the screen. but I'm encountering the following screen.
I don't know if you can have such support.
VNC connection is open. Can we connect and look together?
Even if I deploy the page as empty, it still doesn't appear. The following error screen appears.
Just add a button
Which means you see a red triangle on the node, meaning: error, you have to configure it first.
15
Yes, thank you very much
