Hello good morning.
My UI stoped display today and only displays connection lost at the bottom left of the screen. I have lost of dashboard nodes in my flow but still cant get anything in the ui
Connection lost means that node-red is probably stopped. Have you checked it it is still active?
Also make sure to refresh your browser.
Yes node red is still active. I have refreshed the browser and even try using a different one but i got the same problem.
What happens if you stop/restart NR?
nothing changed. i just did that now.
Does it work on the node-red machine if you open http://localhost:1880/ui/ ?
What is the IP of your node-red machine? Is it DHCP? Perhaps it has a new IP address?
Have you looked at the startup log from node-red to see if there is anything there. Depending on how you installed it you may be able to get that by running
node-red-stop
node-red-start
Possibly worth posting it here.
Have you installed another dashboard possibly?
its the same thing in localhost. blank screen with connection lost.
i did this too but nothing changed
Did you make any changes just before this happened?
Please export your flow and attach it to a reply (read this first)
Did what? Also you haven't posted the log.
here is the log
$ node-red-log
- /usr/lib/node_modules/node-red/node_modules/@node-red/registry/lib/loader.js
- /usr/lib/node_modules/node-red/node_modules/@node-red/registry/lib/index.js
- /usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/index.js
- /usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/index.js
- /usr/lib/node_modules/node-red/lib/red.js
- /usr/lib/node_modules/node-red/red.js
20 May 14:18:48 - [warn] ------------------------------------------------------
20 May 14:18:48 - [info] Settings file : /home/pi/.node-red/settings.js
20 May 14:18:48 - [info] Context store : 'default' [module=memory]
20 May 14:18:48 - [info] User directory : /home/pi/.node-red
20 May 14:18:48 - [warn] Projects disabled : editorTheme.projects.enabled=false
20 May 14:18:48 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
20 May 14:18:48 - [info] Server now running at http://127.0.0.1:1880/
We need to see the beginning. Please run
node-red-stop
node-red-start
and paste it all here.
pi@raspberrypi:~ $ node-red-stop
Stop Node-RED
Use node-red-start to start Node-RED again
pi@raspberrypi:~ $ node-red-start
Start Node-RED
Once Node-RED has started, point a browser at http://192.168.8.102:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use node-red-stop to stop Node-RED
Use node-red-log to view the recent log output
Use sudo systemctl enable nodered.service to autostart Node-RED at every boot
Use sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
21 May 07:06:15 - [info]
Welcome to Node-RED
21 May 07:06:15 - [info] Node-RED version: v1.0.6
21 May 07:06:15 - [info] Node.js version: v10.19.0
21 May 07:06:15 - [info] Linux 4.19.97-v7+ arm LE
21 May 07:06:19 - [info] Loading palette nodes
21 May 07:06:25 - [info] Dashboard version 2.22.1 started at /ui
21 May 07:06:26 - [info] Settings file : /home/pi/.node-red/settings.js
21 May 07:06:26 - [info] Context store : 'default' [module=memory]
21 May 07:06:26 - [info] User directory : /home/pi/.node-red
21 May 07:06:26 - [warn] Projects disabled : editorTheme.projects.enabled=false
21 May 07:06:26 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
21 May 07:06:26 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
21 May 07:06:26 - [info] Starting flows
21 May 07:06:26 - [warn] [telegram sender:Your bot] bot not initialized.
21 May 07:06:26 - [warn] [telegram command:chenko] bot not initialized.
21 May 07:06:26 - [warn] [telegram sender:Send response] bot not initialized.
21 May 07:06:26 - [warn] [telegram command:a79b749a.278748] bot not initialized.
21 May 07:06:27 - [warn] [telegram receiver:c4ce3ebf.5ae48] bot not initialized
21 May 07:06:27 - [warn] [telegram sender:Send response] bot not initialized.
21 May 07:06:31 - [info] Started flows
21 May 07:06:31 - [error] [sqlitedb:568a490c.da4d38] failed to open /home/pi/sqlite/diagnostic
21 May 07:06:31 - [error] [sqlitedb:e9514121.111fd] failed to open /home/pi/dbs/iot.db
21 May 07:06:31 - [info] [mqtt-broker:locahost] Connection failed to broker: note1@mqtt://localhost:1883
1.Is the node-red editor working ok?
2. Do you expect all those errors and warnings in the log? If not then it might be worth sorting those in case the problem is a side effect of one of those.
3. If you run top in a terminal is it showing that node red is using lots of processor?
Yes the node red editor is working very well with no issues
I dont understand the second point
Wen i do top i dont get anything about node red.
I have even reinstalled node red the same thing. I went on as to even flashing my pi back to a raspbian but still the same errors.
What @Colin was asking it there are numorus [warn] and two [error] messages in the startup log and they may be part of the problem.
- go into your flow and disable the telegram node and sqlite node - down in the lower left of every node is a enable/disable button. So disable those nodes.
- the first image you posted looks like it you were accessing the dashboard from a phone. What if yo access it from the NR editor?
I disabled the nodes and also access the ui using the second means and dere was no different
Hello
Thanks very much to every one who help i finally opened a new flow added a ui node dere configured it, then restarted node red and boom the ui was there
