Dashboard 2 No UI
Probably addressed somewhere but I couldn't find it...
Anyway I've Installed Dashboard 2. all seem to go well but when I go to the UI I get a white screen and the text cannot Get/UI. Any assistance would be appreciated!
Cheers!
Can you show us the node red startup log please (copy/paste, not screenshot).
Also what URL are you using for the node red editor and for the dashboard?
Welcome to Node-RED
3 Jul 12:50:07 - [info] Node-RED version: v4.0.2
3 Jul 12:50:07 - [info] Node.js version: v20.15.0
3 Jul 12:50:07 - [info] Linux 6.6.31+rpt-rpi-v8 arm64 LE
3 Jul 12:50:07 - [info] Loading palette nodes
3 Jul 12:50:09 - [info] Settings file : /home/jim/.node-red/settings.js
3 Jul 12:50:09 - [info] Context store : 'default' [module=memory]
3 Jul 12:50:09 - [info] User directory : /home/jim/.node-red
3 Jul 12:50:09 - [warn] Projects disabled : editorTheme.projects.enabled=false
3 Jul 12:50:09 - [info] Flows file : /home/jim/.node-red/start
3 Jul 12:50:09 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
3 Jul 12:50:09 - [info] Starting flows
3 Jul 12:50:09 - [info] [ui-base:My Dashboard] Node-RED Dashboard 2.0 (v1.12.4) started at /dashboard
3 Jul 12:50:09 - [info] [ui-base:My Dashboard] Created socket.io server bound to Node-RED port at path /dashboard/socket.io
3 Jul 12:50:09 - [info] Started flows
10.0.1.55:1880 for the editor -- Works as expected...
10.0.1.55:1880/ui for the UI
It is /dashboard for D2
I guess I don't understand your statement??
It is not /ui, it is /dashboard.
Thank you! I just figured that out as well...
Cheers!
There is a clickable link shortcut in the dashboard sidebar to save you entering the URL manually.
