have successfully password protected my node-red UI which is installed on my desktop. I am trying to do the same with the node-red UI on my IBM bluemix account.
I have read the relevant settings are located in the "bluemix-settings.js" file,
What's the code I need to put in there to password protect the UI?
@Sirhc when you first deployed Node-RED into IBM Cloud it would have taken you through a startup wizard that allows you to setup username/password for your instance. Did you go through that?
