As you can see below, I have two levels of grouping data
The calculation is right for the second level but not for the first level.
Any idea
Thanks in advance
Please send a reduced flow highlighting the issue, so I can investigate
Thanks for your anwer !
So can you confirm that sum should appear in top-level group too ?
Properties from ui_tabulator
"height": 580,
"layout": "fitColumns",
"selectable": true,
"groupBy": ["espace","categorie"],
"groupStartOpen": true,
"addRowPos": "top",
"columnCalcs":"group",
"groupClosedShowCalcs":true,
"columns": [
"field": "id",
"editable":false,
"visible": false
"title": "Espace",
"field": "espace",
"hozAlign": "left",
"editable": false,
"visible": false
"title": "Catégorie",
"field": "categorie",
"width": "0%",
"hozAlign": "left",
"editor": "input",
"editable": false,
"visible": false
"title": "Index",
"field": "cctp",
"formatter": "input",
"width": "5%",
"hozAlign": "left",
"editable": true,
"editor": "input"
"title": "Titre",
"field": "titre",
"width": "20%",
"hozAlign": "left",
"editable": false,
"editor": "input"
"title": "Description",
"field": "description",
"formatter": "textarea",
"width": "20%",
"hozAlign": "left",
"editable": true,
"editor": "textarea"
"title": "PU",
"field": "prixUnitaire",
"width": "10%",
"hozAlign": "center",
"editor":"input",
"editable": true
"title": "Q",
"field": "quantite",
"editable": true,
"width": "5%",
"editor": "input"
"title": "PT",
"field": "prixTotal",
"width": "10%",
"editable": false,
"topCalc":"@F:somme"
"field": "modele",
"visible": false
"title": "Zone",
"field": "zone",
"width": "10%",
"hozAlign": "left",
"editable": false,
"editor": "input"
"title": "Niveau",
"field": "niveau",
"width": "5%",
"hozAlign": "left",
"editable": false,
"editor": "input"
"title": "Modèle",
"field": "designation",
"width": "15%",
"hozAlign": "left",
"editable": false,
"editor": "input"
and fonction somme
function somme(values, params) {
var calc = 0;
values.forEach(function(element) {
element = element.slice(0,-2);
element = element.replace(/\u00A0/g, '');
element = element.replace(/,/g, '.');
calc += parseFloat(element);
calc = calc.toLocaleString("fr-FR", { style: "currency", currency: "EUR" });
return calc;
This is all about Tabulator functionality.
As much as I can see (you are welcome to dig further into the tabulator documentation), Tabulator can show the column calculation in group level, table level or both, but not in the top group
You may consider adding a function which shows the top group sum in its title.
A few more things:
