Noisecraft - anyone heard of it?
I would disagree that VP didn't take off. It most certainly did. And in many forms. Blockly, for example is used in many (most?) schools to teach computer logic and programming before moving on to written languages (usually Python). And visual tools are used in hundreds of different products and have been available for decades. Blockly, LabView, Microsoft PowerPlatform (itself several generations down a visual programming path), .... - the list goes on and on.
Currently, I would suggest that AI is perceived as an easy way out of having to think about logic at all! Ask a question, get your answer. No need to map out the logic.
Of course, this is a total fallacy. Since the only logic that LLM tools supply is the logic someone else has already laid out. It is a dead-end. But everyone is excited because they think it is a quick and easy way out of having to actually think for themselves. LLM's are also a somewhat dangerous dead-end in that the cost to both train and run them is enormous and likely to be highly unsustainable. Make use of free ones while you can. (Though maybe someone will invent more efficient runtime models, that's the potential of innovation of course).
Not to say that LLM and ML doesn't have a place - and an important one too. But, as usual, it won't be what most people think.
And, on that we certainly both agree.
There are certainly libraries that do this. Let me check my list. :slight_smile: I believe that there are a number of layout theories - math approaches - that can be used as well though that is way above my head.
OK, apologies for the length of the following. Not all of it will be relavent - it comes from my Obsidian knowledgebase and lists many of the graph-based libraries and tools that I'm aware of. Certainly some of these have auto-layout capabilities. Even the venerable graphviz has several auto-layout options.
Name Descr $ Comments
baklavajs Graph/node editor for VueJs 0 Interesting Unreal engine style flow-based display and processing.
beautiful-react-diagrams React components and hooks to build diagrams
butterfly Renderer for interactive diagrams and flowcharts
cytoscape.js Canvas based renderer with utilities and algorithms blog
diagram-maker Interactive editor for any graph-like data 0 Online editor
Flowy Flowchart library 0 Flowcharts only
flow-builder React-based renderer for workflows and process diagrams
Flume A React-powered node editor and runtime engine 0 Unreal engine style flow-based display and processing.
GoJS Diagramming library with a focus on customization and interactivity $$$ Go library
jointjs JavaScript diagramming library $$$
jsplumb Open source project written in Typescript that gives you the tools you need to visually connect DOM elements 0 (Limited), $$$ Free version is too limiting
kedro-viz Visualises Kedro data and machine-learning pipelines Specialist
litegraph.js A graph node engine and editor 0 Unreal engine style flow-based display and processing.
mermaid JavaScript based diagramming and charting tool that renders Markdown-inspired text definitions to create and modify diagrams dynamically. 0 Widely embedded in other tools.
ngx-graph Graph visualization library for Angular Angular only
nice-dag Lightweight javascript library, which is used to present a DAG diagram
nodl Framework for computational node graphs 0 Unreal engine style flow-based display and processing.
Pintora Extensible javascript text-to-diagrams library that works in both browser and Node.js. Inspired by Mermaid and PlantUML 0
react-dag-editor React component to create graphic user interface
react-digraph A library for creating directed graph editors
react-flow React library for rendering node-based UIs
reaflow React library for building workflow editors
rete Framework for visual programming and node editors 0 Unreal engine style flow-based display and processing.
sigma.js Visualization framework for large graphs
vue-flow Flowchart component for Vue 3 Simplified graph view
X6 X6 is an HTML and SVG-based graph editing engine that provides low-cost customization capabilities and out-of-the-box built-in extensions to quickly build DAG diagrams, ER diagrams, flowcharts, lineage diagrams, and more. Mostly Chinese.
Apache ECharts
Website Docs GitHub
Includes Graph types.
Arbor.js
arbor.js » introduction (arborjs.org) samizdatco/arbor: a graph visualization library using web workers and jQuery (github.com)
"a graph visualization library built with web workers and jQuery."
D3.js
Website Docs GitHub
Data visualisation
d3-graphviz
magjac/d3-graphviz: Graphviz DOT rendering and animated transitions using D3 (github.com)
Dracula
strathausen/dracula: JavaScript layout and representation of connected graphs. (github.com) Dracula Graph Library – Graph Computation, Layout, Algorithms for JavaScript (graphdracula.net)
G6 (AntV)
Introduction | G6 (gitee.io)
Graphviz (C)
DOT Language. Command line only.
Vega - Incl Tree & Network views
A Visualization Grammar | Vega
Vis.js (Community Edition) - Incl Network view
vis.js (visjs.org)
A dynamic, browser based visualization library. The library is designed to be easy to use, to handle large amounts of dynamic data, and to enable manipulation of and interaction with the data. The library consists of the components DataSet, Timeline, Network, Graph2d and Graph3d.
VivaGraphJS
website
Layouting
  • elkjs - A port of the Java ELK layouting library to Javascript
  • d3-hierarchy - Helpers and algorithms for working with hierarchical graphs
  • d3-force - Library for creating interactive force directed graphs
  • d3-dag - D3 plugin to work with DAG data structures
  • dagrejs - Directed graph layout algorithms for Javascript
  • graphology-layout - Layout algorithms
  • springy - Force directed graph layouts
Graph Utilities
  • behave-graph - Extensible behaviour-graph execution engine
  • graphlib - Helpers for directed graphs in JS
  • graphology - Utilities and algorithms for all kinds of graphs
Misc
  • flume - Business logic graph editor
  • mermaid - Flowchart and sequence diagrams generation
  • pintora - Text-to-diagrams library
  • quick-erd - Generate entity-relationship diagrams (ERD) from text, and reverse engineer ERD text from live database
Overview | Welcome to PyFlow homepage! (wonderworks-software.github.io) is a general purpose visual scripting framework for python.
Ryven - Flow-based visual scripting for Python - A simple and powerful visual nodes editor for Python, and a framework for building nodes executing any Python code.
