Non-http transport requested
I am trying to get xml data from a weather web server. When I use this URL in a browser it works fine and I receive the xml data.
URL:https://api.weatherlink.com/v1/StationStatus.xml?user=001D0A00DE6A&pass=DEMO&apiToken=demo0a002bc5272033001d0a002bc527
If I put the same URL into a "http node request" then I just receive "non-http transport requested" error. I looked around about this error but I did not find any description or definition.
Am I doing something wrong?
Any clue?
thank you
JZ
[{"id":"4f7f0495.ab424c","type":"inject","z":"15355a7e.125016","name":"Tick","topic":"","payload":"","payloadType":"date","repeat":"120","crontab":"","once":true,"x":225.99998474121094,"y":254.3333282470703,"wires":[["de26ba05.65fbf8"]]},{"id":"de26ba05.65fbf8","type":"http request","z":"15355a7e.125016","name":"Davis weatherLink","method":"POST","ret":"txt","url":" https://api.weatherlink.com/v1/StationStatus.xml?user=001D0A00DE6A&pass=DEMO&apiToken=demo0a002bc5272033001d0a002bc527","tls":"46469723.30c598","x":410.16665267944336,"y":254.33333587646484,"wires":[["ea945ecb.57d38","646b371b.4f2198"]]},{"id":"ea945ecb.57d38","type":"xml","z":"15355a7e.125016","name":"","attr":"","chr":"","x":587.6666526794434,"y":254.33333587646484,"wires":[["5e607ee.0b0148"]]},{"id":"646b371b.4f2198","type":"debug","z":"15355a7e.125016","name":"","active":true,"console":"false","complete":"false","x":618.5,"y":299,"wires":[]},{"id":"46469723.30c598","type":"tls-config","z":"","name":"","cert":"","key":"","ca":"","certname":"","keyname":"","caname":"","verifyservercert":true}]
I think you probably want GET rather than POST, and don't tick Enable Secure, and take the space off the front of the URL.
Hi Jose,
If it shouldn't work after all the recommendations from Colin, please have a look at my node-red-contrib-http-logger node. This allows you to see which http request is being send by Node-RED. You can then compare that request with the request send by your browser (which you can easily display with the developer tools of your browser)...
Good luck!
Bart
Thank you Colin. (good observer).
In fact the problem was the additional space at the beginning of URL. :slight_smile:
It's working fine. Simple solution !
@Bart
Thank you for the tool you suggested. I tested it, it's quite interesting for debugging and /or understand data interchange between server and client. :+1:
kind regards
JZ
You also shouldn't be using post or have the TLS box checked.
Ok Colin, agree.
I will remove the TLS and use GET.
Thanks again
JZ
Hi, I used your flow to get the vantage pro 2 measurement and I put GET as you marked and If I put the same URL into a "http node request" after changing user, password and apiToken then I just receive "non-http transport requested" error.
Could you please help me.
abbas
Thank you Colin. I had the same issue and tried too many things it took too long to find the issue. I still can't believe that it was just a space.
Thank you again. You are a life saver.
