Working Ambient Weather API flow
Hey folks,
I've found where some have had issues pulling data from their Ambient Weather stations. Here's the simple http get URL to pull your data.
Get your API key here https://dashboard.ambientweather.net/account
https://api.ambientweather.net/v1/devices?applicationKey=???????????????&apiKey=???????????????
Capture
        "id": "de72930d.400e1",
        "type": "tab",
        "label": "ambientweather",
        "disabled": false,
        "info": ""
        "id": "c2e3aede.aa85e8",
        "type": "http request",
        "z": "de72930d.400e1",
        "method": "GET",
        "ret": "txt",
        "url": "https://api.ambientweather.net/v1/devices?applicationKey=???????????????&apiKey=???????????????",
        "tls": "",
        "x": 280,
        "y": 300,
                "64227587.f0bbdc"
        "id": "de1d339d.bf4308",
        "type": "inject",
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 240,
        "y": 240,
                "c2e3aede.aa85e8"
        "id": "9c3ddec7.f368f",
        "type": "debug",
        "name": "Temperature F",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "x": 520,
        "y": 420,
        "id": "64227587.f0bbdc",
        "type": "json",
        "property": "payload",
        "action": "",
        "pretty": false,
        "x": 310,
        "y": 360,
                "ce2f5475.9056b",
                "5c7f7273.8f711c"
        "id": "ce2f5475.9056b",
        "type": "change",
        "name": "AWtempf",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "payload[0].lastData.tempf",
                "tot": "msg"
                "t": "set",
                "p": "tempf",
                "pt": "flow",
                "to": "payload.AWtempf",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 300,
        "y": 420,
                "9c3ddec7.f368f"
        "id": "5c7f7273.8f711c",
        "type": "debug",
        "name": "All Data",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "x": 500,
        "y": 360,
Here is one with Zabbix and MQTT hooks based on openweather API.
It also has the python reading MCP9808 Sensor, and the Pi 4 CPU Temp.
        "id": "6acc9db.7a04264",
        "type": "tab",
        "label": "Proelian",
        "disabled": false,
        "info": ""
        "id": "e64e333f.e4b22",
        "type": "file in",
        "z": "6acc9db.7a04264",
        "name": "thermal_zone0_temp",
        "filename": "/sys/class/thermal/thermal_zone0/temp",
        "format": "utf8",
        "chunk": false,
        "sendError": false,
        "encoding": "none",
        "x": 340,
        "y": 280,
                "9d7032b3.4df9f8"
        "id": "41b964aa.16c99c",
        "type": "inject",
        "topic": "",
        "payload": "",
        "repeat": "15",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 110,
        "y": 40,
                "bcbb7c72.8805d",
                "90657ec7.3489"
        "id": "bcbb7c72.8805d",
        "type": "function",
        "func": "msg.filename=\"/sys/class/thermal/thermal_zone0/temp\";\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 150,
        "y": 280,
                "e64e333f.e4b22"
        "id": "9d7032b3.4df9f8",
        "type": "calculator",
        "inputMsgField": "payload",
        "outputMsgField": "payload",
        "operation": "div",
        "constant": "1000",
        "x": 510,
        "y": 280,
                "ed6ce4cb.aadb6",
                "ff9f4473.0a6e2",
                "cda8a21f.30fd3"
        "info": "msg.payload = [\n    \"system.cpu.temp\",\n        msg.payload\n]"
        "id": "df9d40fa.99fd78",
        "type": "openweathermap in",
        "name": "Openweathermap",
        "wtype": "current",
        "lon": "",
        "lat": "",
        "city": "San Andreas",
        "country": "California",
        "language": "en",
        "x": 100,
        "y": 780,
                "777b03c9.e1a804",
                "58bdc1c1.c8c78"
        "id": "4b774407.efeda4",
        "type": "zabbix-sender",
        "zabbixServer": "127.0.0.1",
        "zabbixPort": 10051,
        "sendTimestamps": false,
        "withNs": false,
        "timeout": 5000,
        "defaultHostname": "Zabbix server",
        "x": 1470,
        "y": 370,
        "id": "ed6ce4cb.aadb6",
        "type": "function",
        "name": "Zabbix Array",
        "func": "var payload=msg.payload;\nmsg.payload = ['Zabbix server', 'system.cpu.temp', payload ]\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 750,
        "y": 320,
                "4b774407.efeda4"
        "id": "777b03c9.e1a804",
        "type": "function",
        "name": "Openweather Zabbix Function",
        "func": "var payload=msg.payload;\nmsg.payload = [\n    ['Zabbix server', 'openweather.tempk', payload.tempk ],\n    ['Zabbix server', 'openweather.maxtemp', payload.maxtemp ],\n    ['Zabbix server', 'openweather.mintemp', payload.mintemp ],\n    ['Zabbix server', 'openweather.tempc', payload.tempc ],\n    ['Zabbix server', 'openweather.temp_maxc', payload.temp_maxc ],\n    ['Zabbix server', 'openweather.temp_minc', payload.temp_minc ],\n    ['Zabbix server', 'openweather.humidity', payload.humidity ],\n    ['Zabbix server', 'openweather.pressure', payload.pressure ],\n    ['Zabbix server', 'openweather.windspeed', payload.windspeed ],\n    ['Zabbix server', 'openweather.winddirection', payload.winddirection ],\n    ['Zabbix server', 'openweather.sunrise', payload.sunrise ],\n    ['Zabbix server', 'openweather.sunset', payload.sunset ],\n    ['Zabbix server', 'openweather.clouds', payload.clouds ]\n]    \nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 500,
        "y": 370,
                "4b774407.efeda4"
        "id": "58bdc1c1.c8c78",
        "type": "function",
        "name": "Openweather Dashboard Function",
        "func": "var msg1 = { payload:msg.payload.temp_maxc };\nmsg1.topic = \"Max\";\nvar msg2 = { payload:msg.payload.tempc };\nmsg2.topic = \"Current\";\nvar msg3 = { payload:msg.payload.temp_minc };\nmsg3.topic = \"Min\";\nvar msg4 = { payload:msg.payload.description};\nvar msg5 = { payload:msg.payload.icon};\nvar msg6 = { payload:msg.payload.pressure};\nvar msg7 = { payload:msg.payload.humidity};\nvar msg8 = { payload:msg.payload.clouds};\nvar msg9 = { payload:msg.payload.windspeed};\nvar msg10 = { payload:msg.payload.winddirection};\nvar msg11 = { payload:msg.payload.sunrise};\nvar msg12 = { payload:msg.payload.sunset};\nvar msg13 = { payload:msg.location};\nreturn [ msg1, msg2, msg3, msg4, msg5, msg6, msg7, msg8, msg9, msg10, msg11, msg12, msg13 ];",
        "outputs": 13,
        "noerr": 0,
        "x": 500,
        "y": 780,
                "e08f590.57f33a8",
                "57dff58e.8ec274"
                "e08f590.57f33a8",
                "c75ee5d0.8550e"
                "e08f590.57f33a8",
                "e6350e56.21106"
                "302cf849.6a4e58"
                "fb81c77f.51b148"
                "fca87095.0adfc",
                "30720f6d.cc00b"
                "41070f1f.5a77e8",
                "383c6806.493288"
                "e8be6823.2e7978",
                "7721052c.889044"
                "583d26ff.d270e8",
                "4dc13725.0a2d28"
                "8a47c24c.a5be78"
        "outputLabels": [
            "Temp Max",
            "Current Temp",
            "Temp Min",
            "Description",
            "Weather icon",
            "Pressure",
            "Humidity",
            "Clouds",
            "Wind Speed",
            "Wind Direction",
            "Sunrise",
            "Sunset",
            "Location"
        "id": "9557f682.c2d048",
        "type": "ui_gauge",
        "name": "Max Temp",
        "group": "c10a76da.b6e7d8",
        "order": 13,
        "width": 4,
        "height": 4,
        "gtype": "gage",
        "title": "Max Temp",
        "label": "",
        "format": "{{value | number:2}} ºF",
        "min": "-15",
        "max": "120",
        "colors": [
            "#0080ff",
            "#008080",
            "#ca3838"
        "seg1": "60",
        "seg2": "80",
        "x": 1220,
        "y": 720,
        "id": "9d3a2b43.a1bbc8",
        "type": "ui_gauge",
        "name": "Current Temperature",
        "order": 12,
        "width": 4,
        "height": 4,
        "gtype": "gage",
        "title": "Current Temperature",
        "label": "",
        "min": "-15",
        "max": "120",
        "colors": [
            "#0080ff",
            "#008040",
            "#ca3838"
        "seg1": "60",
        "seg2": "80",
        "x": 1260,
        "y": 760,
        "id": "caca4a17.cfd48",
        "type": "ui_gauge",
        "name": "Min Temp",
        "order": 11,
        "width": 4,
        "height": 4,
        "gtype": "gage",
        "title": "Min Temp",
        "label": "",
        "min": "-15",
        "max": "120",
        "colors": [
            "#0080ff",
            "#008080",
            "#ca3838"
        "seg1": "60",
        "seg2": "80",
        "x": 1220,
        "y": 800,
        "id": "e08f590.57f33a8",
        "type": "ui_chart",
        "name": "Temperature - Celcius",
        "group": "a3bb27b0.21c0f8",
        "order": 2,
        "width": 18,
        "height": 4,
        "label": "Temperature - Celcius",
        "chartType": "line",
        "legend": "true",
        "xformat": "HH:mm:ss",
        "interpolate": "linear",
        "nodata": "",
        "dot": false,
        "ymin": "-5",
        "ymax": "50",
        "removeOlder": "30",
        "removeOlderPoints": "",
        "removeOlderUnit": "86400",
        "cutout": 0,
        "useOneColor": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "useOldStyle": false,
        "outputs": 1,
        "x": 1260,
        "y": 520,
        "id": "302cf849.6a4e58",
        "type": "ui_text",
        "group": "5aa0cc20.177064",
        "order": 1,
        "width": 18,
        "height": 2,
        "label": "",
        "format": "{{msg.payload}}",
        "layout": "row-left",
        "x": 1210,
        "y": 840,
        "id": "fb81c77f.51b148",
        "type": "ui_template",
        "name": "Weather icon",
        "order": 2,
        "width": 12,
        "height": 2,
        "format": "<div style=\"display: flex;height: 100%;justify-content: center;align-items: center;\">\n<i class=\"fa-3x wi wi-owm-{{msg.payload}}\"></i>\n</div>",
        "storeOutMessages": true,
        "fwdInMessages": true,
        "templateScope": "local",
        "x": 1240,
        "y": 880,
        "id": "fca87095.0adfc",
        "type": "ui_gauge",
        "name": "Pressure",
        "order": 14,
        "width": 4,
        "height": 4,
        "gtype": "gage",
        "title": "Pressure",
        "label": "MBAR",
        "format": "{{value | number:2}}",
        "min": "900",
        "max": "1050",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "1015",
        "seg2": "1023",
        "x": 1220,
        "y": 920,
        "id": "41070f1f.5a77e8",
        "type": "ui_gauge",
        "name": "Humidity",
        "order": 15,
        "width": 4,
        "height": 4,
        "gtype": "gage",
        "title": "Humidity",
        "label": "",
        "format": "{{value | number:2}}%",
        "min": 0,
        "max": "100",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "45",
        "seg2": "55",
        "x": 1220,
        "y": 960,
        "id": "583d26ff.d270e8",
        "type": "ui_gauge",
        "name": "Windspeed",
        "order": 2,
        "width": 4,
        "height": 4,
        "gtype": "donut",
        "title": "Windspeed",
        "label": "Miles per Hour",
        "min": 0,
        "max": "110",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "5",
        "seg2": "7",
        "x": 1230,
        "y": 1040,
        "id": "8a47c24c.a5be78",
        "type": "ui_gauge",
        "name": "Wind Direction",
        "order": 3,
        "width": 4,
        "height": 4,
        "gtype": "compass",
        "title": "Wind Direction",
        "label": "Degrees",
        "format": "{{value}}",
        "min": 0,
        "max": "359",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 1240,
        "y": 1080,
        "id": "e8be6823.2e7978",
        "type": "ui_gauge",
        "name": "Clouds",
        "order": 16,
        "width": 4,
        "height": 4,
        "gtype": "gage",
        "title": "Clouds",
        "label": "",
        "min": 0,
        "max": "100",
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "x": 1220,
        "y": 1000,
        "id": "30720f6d.cc00b",
        "type": "ui_chart",
        "name": "Pressure",
        "group": "f468656d.3ff56",
        "order": 1,
        "width": 18,
        "height": 4,
        "label": "Pressure",
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "900",
        "ymax": "1100",
        "removeOlder": "15",
        "cutout": 0,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "x": 1220,
        "y": 560,
        "id": "383c6806.493288",
        "type": "ui_chart",
        "name": "Humidity",
        "group": "9e32a364.0d0a",
        "order": 1,
        "width": 17,
        "height": 4,
        "label": "Humidity",
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "0",
        "ymax": "100",
        "cutout": 0,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "x": 1220,
        "y": 600,
        "id": "7721052c.889044",
        "type": "ui_chart",
        "name": "Clouds",
        "group": "f8396000.d0334",
        "order": 1,
        "width": 18,
        "height": 4,
        "label": "Clouds",
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "0",
        "ymax": "100",
        "cutout": 0,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "x": 1220,
        "y": 680,
        "id": "cda8a21f.30fd3",
        "type": "ui_chart",
        "name": "CPU Temperature - Celcius",
        "group": "2db625cf.759fb2",
        "order": 2,
        "width": 30,
        "height": 6,
        "label": "CPU Temperature - Celcius",
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "cutout": 0,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "x": 800,
        "y": 240,
        "id": "ff9f4473.0a6e2",
        "type": "unit-converter",
        "category": "temperature",
        "inputUnit": "C",
        "outputUnit": "F",
        "inputField": "payload",
        "outputField": "payload",
        "inputFieldType": "msg",
        "outputFieldType": "msg",
        "name": "C to F Conversion",
        "x": 770,
        "y": 280,
                "25d351b5.0d983e"
        "id": "25d351b5.0d983e",
        "type": "ui_chart",
        "name": "CPU Temperature - Fahrenheit",
        "order": 1,
        "width": 30,
        "height": 6,
        "label": "CPU Temperature - Fahrenheit",
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "cutout": 0,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "x": 1010,
        "y": 280,
        "id": "57dff58e.8ec274",
        "inputUnit": "C",
        "outputUnit": "F",
        "x": 800,
        "y": 520,
                "2cec0989.5a6ade",
                "9557f682.c2d048"
        "id": "c75ee5d0.8550e",
        "inputUnit": "C",
        "outputUnit": "F",
        "x": 800,
        "y": 560,
                "2cec0989.5a6ade",
                "9d3a2b43.a1bbc8"
        "id": "e6350e56.21106",
        "inputUnit": "C",
        "outputUnit": "F",
        "x": 800,
        "y": 600,
                "2cec0989.5a6ade",
                "caca4a17.cfd48"
        "id": "2cec0989.5a6ade",
        "type": "ui_chart",
        "name": "Temperature -  Fahrenheit",
        "order": 1,
        "width": 18,
        "height": 4,
        "label": "Temperature -  Fahrenheit",
        "legend": "true",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "cutout": 0,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "x": 1270,
        "y": 480,
        "id": "90657ec7.3489",
        "type": "python-function",
        "name": "MCP9808 I2C Inquiry",
        "func": "import time\nimport Adafruit_MCP9808.MCP9808 as MCP9808\nimport os\n\nfrom unittest import TestCase, skipIf\nfrom time import time as now\n\n# Define a function to convert celsius to fahrenheit.\ndef c_to_f(c):\n\treturn c * 9.0 / 5.0 + 32.0\n\n# Default constructor will use the default I2C address (0x18) and pick a default I2C bus.\n#\n# For the Raspberry Pi this means you should hook up to the only exposed I2C bus\n# from the main GPIO header and the library will figure out the bus number based\n# on the Pi's revision.\n#\n# For the Beaglebone Black the library will assume bus 1 by default, which is\n# exposed with SCL = P9_19 and SDA = P9_20.\nsensor = MCP9808.MCP9808()\n\n# Optionally you can override the address and/or bus number:\n#sensor = MCP9808.MCP9808(address=0x20, busnum=2)\n\n# Initialize communication with the sensor.\nsensor.begin()\ntemp = sensor.readTempC()\n\ntempc = ('{0:0.3F}'.format(temp))\n\nmsg['topic'] = \"tempc\"\nmsg['payload'] = tempc\n\nreturn msg",
        "outputs": 1,
        "x": 440,
        "y": 40,
                "7936895.3f49978",
                "dc74645d.897bd"
        "id": "7936895.3f49978",
        "inputUnit": "C",
        "outputUnit": "F",
        "x": 660,
        "y": 40,
                "eaa16911.5598d"
        "id": "eaa16911.5598d",
        "type": "function",
        "name": "Change Topic",
        "func": "msg.topic = \"tempf\";\nreturn msg;\n",
        "outputs": 1,
        "noerr": 0,
        "x": 860,
        "y": 40,
                "c18a2e43.512fb8",
                "40bc6f9e.188838"
        "id": "dc74645d.897bd",
        "type": "function",
        "name": "Zabbix local.MCP9808.tempc",
        "func": "var payload=msg.payload;\nmsg.payload = ['Zabbix server', 'local.MCP9808.tempc', payload ]\nreturn msg;\n",
        "outputs": 1,
        "noerr": 0,
        "x": 700,
        "y": 100,
                "4b774407.efeda4"
        "id": "c18a2e43.512fb8",
        "type": "function",
        "name": "Zabbix local.MCP9808.tempf",
        "func": "var payload=msg.payload;\nmsg.payload = ['Zabbix server', 'local.MCP9808.tempf', payload ]\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 1100,
        "y": 40,
                "4b774407.efeda4",
                "f39f77a8.56a948"
        "id": "b69c3b7b.da49a8",
        "type": "iot-datasource",
        "name": "local.MCP9808.tempf",
        "tstampField": "",
        "dataField": "data",
        "disableDiscover": false,
        "x": 1820,
        "y": 40,
        "id": "f39f77a8.56a948",
        "type": "function",
        "func": "var now = ( new Date() ).getTime();\nvar value=msg.payload[2];\nmsg.payload = {\n    tstamp: now,\n    data: value\n};\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 1350,
        "y": 40,
                "1b3ce317.6536a5"
        "id": "1b3ce317.6536a5",
        "type": "change",
        "rules": [
                "t": "change",
                "p": "topic",
                "pt": "msg",
                "from": "tempf",
                "fromt": "str",
                "to": "",
                "tot": "str"
                "t": "delete",
                "p": "_msgid",
                "pt": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1560,
        "y": 40,
                "b69c3b7b.da49a8"
        "id": "40bc6f9e.188838",
        "type": "mqtt out",
        "name": "MCP9808 Temperature",
        "topic": "home/temperature",
        "qos": "",
        "retain": "",
        "broker": "6b8f56d7.82af78",
        "x": 1100,
        "y": 90,
        "id": "fa3f6c4a.f43d58",
        "type": "ui_chart",
        "group": "23419a7a.82931e",
        "order": 1,
        "width": 18,
        "height": 4,
        "label": "Windspeed",
        "legend": "true",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "cutout": 0,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "x": 1230,
        "y": 640,
        "id": "4dc13725.0a2d28",
        "category": "speed",
        "inputUnit": "m/s",
        "outputUnit": "m/h",
        "x": 870,
        "y": 1040,
                "583d26ff.d270e8",
                "fa3f6c4a.f43d58"
        "id": "c10a76da.b6e7d8",
        "type": "ui_group",
        "z": "",
        "name": "Gauges",
        "tab": "b0e039c7.776c88",
        "order": 2,
        "disp": true,
        "width": "12",
        "collapse": false
        "id": "a3bb27b0.21c0f8",
        "type": "ui_group",
        "z": "",
        "name": "Temperature",
        "order": 3,
        "disp": true,
        "width": 18,
        "collapse": true
        "id": "5aa0cc20.177064",
        "type": "ui_group",
        "z": "",
        "name": "Description",
        "order": 1,
        "disp": true,
        "width": 30,
        "collapse": false
        "id": "f468656d.3ff56",
        "type": "ui_group",
        "z": "",
        "name": "Pressure",
        "order": 4,
        "disp": true,
        "width": 18,
        "collapse": true
        "id": "9e32a364.0d0a",
        "type": "ui_group",
        "z": "",
        "name": "Humidity",
        "order": 5,
        "disp": true,
        "width": 18,
        "collapse": true
        "id": "f8396000.d0334",
        "type": "ui_group",
        "z": "",
        "name": "Cloud Cover",
        "order": 6,
        "disp": true,
        "width": "18",
        "collapse": true
        "id": "2db625cf.759fb2",
        "type": "ui_group",
        "z": "",
        "name": "CPU Temperature",
        "tab": "4802b223.98b354",
        "order": 1,
        "disp": true,
        "width": 30,
        "collapse": false
        "id": "6b8f56d7.82af78",
        "type": "mqtt-broker",
        "z": "",
        "name": "PI",
        "broker": "127.0.0.1",
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "compatmode": false,
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "home/temperature",
        "birthQos": "0",
        "birthPayload": "",
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "willTopic": "",
        "willQos": "0",
        "willPayload": ""
        "id": "23419a7a.82931e",
        "type": "ui_group",
        "z": "",
        "order": 7,
        "disp": true,
        "width": "18",
        "collapse": true
        "id": "b0e039c7.776c88",
        "type": "ui_tab",
        "z": "",
        "name": "Weather",
        "icon": "dashboard",
        "disabled": false,
        "hidden": false
        "id": "4802b223.98b354",
        "type": "ui_tab",
        "z": "",
        "name": "Proelian Server",
        "disabled": false,
        "hidden": false
Your flow currently can't be imported, take a look at How to share code or flow json and try again.
Check it now.
Try this.
Hoping that someone can help me. I have tried this flow and I get nothing back.
I tried pasting the URL into Chrome and I get data back... What am I missing?
Which flow did you import? @vlturner or mine?
I did the first one. I have an Ambient Weather station. I tried catching errors and putting in a debug but I am not seeing anything.
I get this back in the browser -
[{"macAddress":"E8:DB:84:9A:EB:89","lastData":{"dateutc":1648004640000,"tempinf":73.6,"humidityin":51,"baromrelin":29.947,"baromabsin":30.136,"tempf":53.4,"battout":1,"humidity":97,"winddir":357,"windspeedmph":0,"windgustmph":0,"maxdailygust":10.3,"hourlyrainin":0,"eventrainin":0,"dailyrainin":0.02,"weeklyrainin":0.421,"monthlyrainin":3.26,"totalrainin":28.996,"solarradiation":0,"uv":0,"batt_co2":1,"feelsLike":53.4,"dewPoint":52.57,"feelsLikein":73.1,"dewPointin":54.3,"lastRain":"2022-03-22T11:16:00.000Z","tz":"America/Los_Angeles","date":"2022-03-23T03:04:00.000Z"},"info":{"name":"South Bay","coords":{"coords":{"lon":-122.8537212,"lat":47.1061404},"address":"5220 Lemon Rd NE, Olympia, WA 98506, USA","location":"Olympia","elevation":34.92913818359375,"geo":{"type":"Point","coordinates":[-122.8537212,47.1061404]}}}}]
Here is the flow -
        "id": "8a27452390de3769",
        "type": "tab",
        "disabled": false,
        "info": ""
        "id": "d7eaa19c8a55d3cd",
        "z": "8a27452390de3769",
        "method": "GET",
        "ret": "txt",
        "paytoqs": "ignore",
        "url": "https://api.ambientweather.net/v1/devices?applicationKey=??&apiKey=??",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "senderr": false,
        "x": 280,
        "y": 300,
                "8d6d15df08e5b293"
        "id": "233acf340d5d29f5",
        "type": "inject",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 240,
        "y": 240,
                "d7eaa19c8a55d3cd"
        "id": "2df333acfba589e0",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "x": 520,
        "y": 420,
        "id": "8d6d15df08e5b293",
        "type": "json",
        "action": "",
        "pretty": false,
        "x": 310,
        "y": 360,
                "a1c764976daa9687",
                "a860e199460bc2c8"
        "id": "a1c764976daa9687",
        "type": "change",
        "name": "AWtempf",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "msg"
                "t": "set",
                "p": "tempf",
                "pt": "flow",
                "tot": "msg"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 300,
        "y": 420,
                "2df333acfba589e0",
                "cf32ecaaea6ad4de"
        "id": "a860e199460bc2c8",
        "type": "debug",
        "name": "All Data",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "x": 500,
        "y": 360,
        "id": "cf32ecaaea6ad4de",
        "type": "ui_gauge",
        "group": "e921b4fb49bd73fd",
        "order": 0,
        "width": 0,
        "height": 0,
        "gtype": "gage",
        "title": "gauge",
        "label": "units",
        "min": 0,
        "max": 10,
        "colors": [
            "#00b500",
            "#e6e600",
            "#ca3838"
        "seg1": "",
        "seg2": "",
        "className": "",
        "x": 440,
        "y": 540,
        "id": "e921b4fb49bd73fd",
        "type": "ui_group",
        "name": "Outdoors",
        "tab": "9eeddfdf15437bc2",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "9eeddfdf15437bc2",
        "type": "ui_tab",
        "name": "Weather",
        "order": 3,
        "disabled": false,
        "hidden": false
Pull your key out of the code real quick...I'll look at it.
It's working just fine for me. See capture. What does your debug say? Are you getting a connection error?
Forgive me for asking... Are you clicking the button left of the timestamp node?
click
Thanks, done on the key
ok that was a duh moment. I forgot to do that. it is working now. I knew it had to be something dumb :slight_smile: Now I just need to loop it and combine with my other temp sensors.
Screenshot 2022-03-23 074124
Have been busy elsewhere. What is the question for me?
Vance L. Turner
1540 Mountain Ranch Rd.
San Andreas, CA 95249
Cell 408-431-5595
