Noob Question: Change Data Node divide array by 10
Hi there,
first steps with node red modbus and knx.
I want to grab an outside temperature from an modbus device, this device sends the temperatue as array which should divided by 10.
polling : msg.payload : array[1]
array[1]
0: 184
This message is generated by "node-red-contrib-modbus" and the node "Modbus-Read". The above message should be 18,4 C°...i need this message as 18,4
So i place a change node in between and do the following rule
set "msg.payload"
to the value "jsonata" $number(payload)/10
But i receive
"Invalid JSONata expression: Argument 1 of function "number" does not match function signature"
So what i am doing wrong and how do i get the result i want? I have to divide by 10
payload is an array, the value is at payload[0]
Try
 $number(payload[0])/10;
works, thank you
Think i understood the mistake, not a single value (even there is only one) and have to point to the value position.
