Not sure how to deal with httpAdminRoot
Hi folks,
Got an issue today on Github about one of my nodes. The user has uncommented this part of his settings.js file:
httpAdminRoot: '/admin',
And then the images of my node cannot be loaded anymore from his docker container...
So I wanted to reproduce this problem on my Windows 10 portable running Node-RED:
  1. I uncommented that line in my settings.js file
  2. Now as expected I had to add /admin in my browser's address bar to be able to connect to my flow editor.
  3. But my images are still being loaded correctly (even after clearing the browser cache):
  4. The Network tab indee shows that the images are loaded from the new extended url:
I had expected this to fail (similar to his Docker setup), since my endpoint is not using RED.settings.httpAdminRoot in any way (explicit)...
Can somebody please enlighten me about what I am doing wrong?
Thanks!!
Bart
Not entirely sure what's happening - can't see anything obviously wrong.
One thing you could consider is to remove the needsPermission middleware from that route. - Given the route just serves static images and no actual user/flow data you could legitimately do that - and it should solve the 401 error.
Thanks Nick!
I have asked him whether that solves his problem. Fingers crossed...
It was indeed solved by removing the permission part. Thanks for the tip!!!
This fix for the tank-volume node is now published in the pallette as version 1.0.1:
