Hello people! I would like to know if it is possible to create some widget on the dashboard to show the history of received notifications, for example the last 5, do you know how I can do this? Or if it's possible at least?
what notifications? from where?
If you have an array of 5 things, you can certainly show them on a dashboard yes.
Perhaps something like a log?
Here you find a basic example. One post later you find the code to limit the amount of rows to keep.
I thought of sending these notifications to a database with a timestamp and then pulling them to a table
So why not do that? Send the msg to a database node to record it. Else where you can have a flow that triggers however you want and select the rows descending with a ‘Limit’ clause
- What database are you using?
- How are you triggering the select?
- What are the sql statements you are using for the insert and select?
- What is the schema for the table?
- What database node are you using - the full name please node-red-contrib-?????
1 - Cloudant
2 - I didn't understand very well, I'm a bit new in this area, I'm managing to put the data in the database calmly, but I need something to activate the output, is that it?
3 -
4 - There will be two columns, one with the text of the last notification and the other is the time, showing when it was displayed in the dashboard
5 - node-red-contrib-cloudantplus
Cloudant… I was wondering about that. I have no experience with it so I will have to bow out here unless you want to use a sql database.
Is there a particular reason you are using cloutant?
