Npm update error "Cannot convert undefined or null to object"
When running "npm update" in my ./.node-red directory I get the error "Cannot convert undefined or null to object". The Idealtree seems to run to completion. The error log looks like this:
0 verbose cli /usr/bin/node /usr/bin/npm
1 info using npm@8.18.0
2 info using node@v16.17.0
3 timing npm:load:whichnode Completed in 1ms
4 timing config:load:defaults Completed in 5ms
5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 3ms
6 timing config:load:builtin Completed in 3ms
7 timing config:load:cli Completed in 13ms
8 timing config:load:env Completed in 1ms
9 timing config:load:file:/home/pi/.node-red/.npmrc Completed in 1ms
10 timing config:load:project Completed in 6ms
11 timing config:load:file:/home/pi/.npmrc Completed in 3ms
12 timing config:load:user Completed in 4ms
13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
14 timing config:load:global Completed in 2ms
15 timing config:load:validate Completed in 2ms
16 timing config:load:credentials Completed in 3ms
17 timing config:load:setEnvs Completed in 2ms
18 timing config:load Completed in 44ms
19 timing npm:load:configload Completed in 45ms
20 timing npm:load:mkdirpcache Completed in 2ms
21 timing npm:load:mkdirplogs Completed in 2ms
22 verbose title npm update
23 verbose argv "update"
24 timing npm:load:setTitle Completed in 4ms
25 timing config:load:flatten Completed in 11ms
26 timing npm:load:display Completed in 17ms
27 verbose logfile logs-max:10 dir:/home/pi/.npm/_logs
28 verbose logfile /home/pi/.npm/_logs/2022-09-07T09_53_16_849Z-debug-0.log
29 timing npm:load:logFile Completed in 17ms
30 timing npm:load:timers Completed in 1ms
31 timing npm:load:configScope Completed in 0ms
32 timing npm:load Completed in 93ms
33 timing arborist:ctor Completed in 2ms
34 silly logfile start cleaning logs, removing 13 files
35 timing idealTree:init Completed in 73ms
36 timing idealTree:userRequests Completed in 1ms
37 silly idealTree buildDeps
38 silly fetch manifest @clysema/node-red-contrib-ui-week-schedule@~0.1.4
39 silly logfile done cleaning log files
40 timing arborist:ctor Completed in 0ms
41 http fetch GET 200 https://registry.npmjs.org/@clysema%2fnode-red-contrib-ui-week-schedule 2509ms (cache revalidated)42 silly fetch manifest bcryptjs@^2.4.3
43 http fetch GET 200 https://registry.npmjs.org/bcryptjs 77ms (cache updated)
44 silly fetch manifest industrialcomm@~1.1.6
45 http fetch GET 200 https://registry.npmjs.org/industrialcomm 746ms (cache revalidated)
46 silly fetch manifest node-red-admin@^0.2.7
47 http fetch GET 200 https://registry.npmjs.org/node-red-admin 230ms (cache revalidated)
48 silly fetch manifest node-red-contrib-bigssh@^1.2.9
49 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-bigssh 242ms (cache revalidated)
50 silly fetch manifest node-red-contrib-binary@~0.1.3
51 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-binary 249ms (cache revalidated)
52 silly fetch manifest node-red-contrib-bitunloader@^0.3.7
53 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-bitunloader 248ms (cache revalidated)
54 silly fetch manifest node-red-contrib-buffer-array@~1.1.0
55 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-buffer-array 694ms (cache revalidated)
56 silly fetch manifest node-red-contrib-buffer-parser@~3.2.2
57 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-buffer-parser 693ms (cache revalidated)
58 silly fetch manifest node-red-contrib-calc@^1.0.5
59 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-calc 253ms (cache revalidated)
60 silly fetch manifest node-red-contrib-calculate@^0.1.4
61 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-calculate 223ms (cache revalidated)
62 silly fetch manifest node-red-contrib-chronos@^1.18.0
63 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-chronos 673ms (cache revalidated)
64 silly fetch manifest node-red-contrib-collector@0.0.1
65 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-collector 218ms (cache revalidated)
66 silly fetch manifest node-red-contrib-combine@~1.8.1
67 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-combine 233ms (cache revalidated)
68 silly fetch manifest node-red-contrib-configurable-interval@~0.9.1
69 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-configurable-interval 688ms (cache revalidated)
70 silly fetch manifest node-red-contrib-controltimer@~0.1.0
71 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-controltimer 710ms (cache revalidated)
72 silly fetch manifest node-red-contrib-cron-plus@^1.5.7
73 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-cron-plus 783ms (cache revalidated)
74 silly fetch manifest node-red-contrib-dashboard-average-bars@0.0.6
75 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-dashboard-average-bars 276ms (cache revalidated)
76 silly fetch manifest node-red-contrib-dashboard-bar-chart-data@^0.9.8
77 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-dashboard-bar-chart-data 221ms (cache revalidated)
78 silly fetch manifest node-red-contrib-dashboard-sum-bars@0.0.1
79 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-dashboard-sum-bars 243ms (cache revalidated)
80 silly fetch manifest node-red-contrib-data-view@0.0.3
81 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-data-view 694ms (cache revalidated)
82 silly fetch manifest node-red-contrib-date@0.0.2
83 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-date 231ms (cache revalidated)
84 silly fetch manifest node-red-contrib-device-stats@~1.1.2
85 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-device-stats 266ms (cache revalidated)
86 silly fetch manifest node-red-contrib-eztimer@~1.2.7
87 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-eztimer 232ms (cache revalidated)
88 silly fetch manifest node-red-contrib-float@~1.0.3
89 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-float 758ms (cache revalidated)
90 silly fetch manifest node-red-contrib-flow-asserter@~0.4.0
91 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-flow-asserter 257ms (cache revalidated)
92 silly fetch manifest node-red-contrib-flow-manager@~0.7.2
93 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-flow-manager 266ms (cache revalidated)
94 silly fetch manifest node-red-contrib-frequency-meter@0.0.1
95 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-frequency-meter 747ms (cache revalidated)
96 silly fetch manifest node-red-contrib-fs-ops@~1.6.0
97 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-fs-ops 234ms (cache revalidated)
98 silly fetch manifest node-red-contrib-heater-controller@~3.0.2
99 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-heater-controller 245ms (cache revalidated)
100 silly fetch manifest node-red-contrib-interpolate@0.0.4
101 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-interpolate 718ms (cache revalidated)
102 silly fetch manifest node-red-contrib-interval@0.0.1
103 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-interval 713ms (cache revalidated)
104 silly fetch manifest node-red-contrib-interval-length@0.0.6
105 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-interval-length 244ms (cache revalidated)
106 silly fetch manifest node-red-contrib-interval-multiples-timer@~1.0.5
107 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-interval-multiples-timer 271ms (cache revalidated)
108 silly fetch manifest node-red-contrib-jsontimer@~1.2.0
109 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-jsontimer 268ms (cache revalidated)
110 silly fetch manifest node-red-contrib-key-value-store@~0.1.8
111 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-key-value-store 230ms (cache revalidated)
112 silly fetch manifest node-red-contrib-logger@0.0.6
113 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-logger 244ms (cache revalidated)
114 silly fetch manifest node-red-contrib-looptimer2@0.0.2
115 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-looptimer2 747ms (cache revalidated)
116 silly fetch manifest node-red-contrib-m-bus@~2.0.0
117 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-m-bus 260ms (cache revalidated)
118 silly fetch manifest node-red-contrib-modbus@^5.23.1
119 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-modbus 688ms (cache revalidated)
120 silly fetch manifest node-red-contrib-moment@~4.0.0
121 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-moment 706ms (cache revalidated)
122 silly fetch manifest node-red-contrib-msg-speed@~2.1.0
123 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-msg-speed 232ms (cache revalidated)
124 silly fetch manifest node-red-contrib-odoo-xmlrpc-2021@^0.1.0
125 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-odoo-xmlrpc-2021 266ms (cache revalidated)
126 silly fetch manifest node-red-contrib-persist@~1.1.1
127 http fetch GET 200 https://registry.npmjs.org/node-red-contrib-persist 277ms (cache revalidated)
128 silly fetch manifest node-red-contrib-pid@^1.1.7
..........Too long to post all of it, but no errors here
2796 timing idealTree:node_modules/puppeteer-core/node_modules/extract-zip Completed in 6ms
2797 timing idealTree:node_modules/@types/yauzl Completed in 0ms
2798 timing idealTree:node_modules/puppeteer-core/node_modules/get-stream Completed in 0ms
2799 silly placeDep node_modules/puppeteer-core agent-base@6.0.2 OK for: https-proxy-agent@5.0.0 want: 6
2800 timing idealTree:node_modules/puppeteer-core/node_modules/https-proxy-agent Completed in 3ms
2801 timing idealTree:node_modules/puppeteer-core/node_modules/agent-base Completed in 0ms
2802 timing idealTree:node_modules/puppeteer-core/node_modules/ms Completed in 0ms
2803 timing idealTree:node_modules/puppeteer-core/node_modules/progress Completed in 0ms
2804 silly placeDep node_modules/puppeteer-core glob@7.2.3 OK for: rimraf@3.0.2 want: ^7.1.3
2805 timing idealTree:node_modules/puppeteer-core/node_modules/rimraf Completed in 3ms
2806 silly placeDep node_modules/puppeteer-core minimatch@3.1.2 OK for: glob@7.2.3 want: ^3.1.1
2807 silly placeDep ROOT path-is-absolute@1.0.1 OK for: glob@7.2.3 want: ^1.0.0
2808 timing idealTree:node_modules/puppeteer-core/node_modules/glob Completed in 6ms
2809 timing idealTree:node_modules/path-is-absolute Completed in 0ms
2810 silly placeDep node_modules/puppeteer-core brace-expansion@1.1.11 OK for: minimatch@3.1.2 want: ^1.1.7
2811 timing idealTree:node_modules/puppeteer-core/node_modules/minimatch Completed in 2ms
2812 timing idealTree:node_modules/puppeteer-core/node_modules/brace-expansion Completed in 0ms
2813 timing idealTree:node_modules/puppeteer-core/node_modules/ws Completed in 0ms
2814 silly placeDep node_modules/puppeteer ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
2815 timing idealTree:node_modules/puppeteer/node_modules/debug Completed in 2ms
2816 timing idealTree:node_modules/puppeteer/node_modules/ms Completed in 0ms
2817 silly placeDep ROOT async-limiter@1.0.1 OK for: ws@6.2.2 want: ~1.0.0
2818 timing idealTree:node_modules/puppeteer/node_modules/ws Completed in 4ms
2819 timing idealTree:node_modules/async-limiter Completed in 0ms
2820 timing idealTree:node_modules/request/node_modules/qs Completed in 0ms
2821 silly placeDep node_modules/rimraf minimatch@3.1.2 OK for: glob@7.2.3 want: ^3.1.1
2822 timing idealTree:node_modules/rimraf/node_modules/glob Completed in 3ms
2823 silly placeDep node_modules/rimraf brace-expansion@1.1.11 OK for: minimatch@3.1.2 want: ^1.1.7
2824 timing idealTree:node_modules/rimraf/node_modules/minimatch Completed in 3ms
2825 timing idealTree:node_modules/rimraf/node_modules/brace-expansion Completed in 1ms
2826 silly placeDep node_modules/send/node_modules/debug ms@2.0.0 OK for: debug@2.6.9 want: 2.0.0
2827 timing idealTree:node_modules/send/node_modules/debug Completed in 3ms
2828 timing idealTree:node_modules/send/node_modules/mime Completed in 0ms
2829 timing idealTree:node_modules/serialport/node_modules/@serialport/parser-delimiter Completed in 0ms
2830 timing idealTree:node_modules/serialport/node_modules/@serialport/parser-readline Completed in 0ms
2831 silly placeDep node_modules/serialport ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
2832 timing idealTree:node_modules/serialport/node_modules/debug Completed in 2ms
2833 timing idealTree:node_modules/serialport/node_modules/ms Completed in 0ms
2834 timing idealTree:node_modules/shortid/node_modules/nanoid Completed in 0ms
2835 silly placeDep node_modules/socket.io-client ms@2.0.0 OK for: debug@3.1.0 want: 2.0.0
2836 timing idealTree:node_modules/socket.io-client/node_modules/debug Completed in 2ms
2837 timing idealTree:node_modules/socket.io-client/node_modules/ms Completed in 0ms
2838 silly placeDep node_modules/socket.io-client isarray@2.0.1 OK for: socket.io-parser@3.3.2 want: 2.0.1
2839 timing idealTree:node_modules/socket.io-client/node_modules/socket.io-parser Completed in 2ms
2840 timing idealTree:node_modules/socket.io-client/node_modules/isarray Completed in 0ms
2841 silly placeDep node_modules/socket.io-parser ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
2842 timing idealTree:node_modules/socket.io-parser/node_modules/debug Completed in 3ms
2843 timing idealTree:node_modules/socket.io-parser/node_modules/ms Completed in 0ms
2844 silly placeDep node_modules/socket.io ms@2.1.2 OK for: debug@4.3.4 want: 2.1.2
2845 timing idealTree:node_modules/socket.io/node_modules/debug Completed in 2ms
2846 timing idealTree:node_modules/socket.io/node_modules/ms Completed in 0ms
2847 timing idealTree:node_modules/streamroller/node_modules/debug Completed in 0ms
2848 silly placeDep node_modules/streamroller isarray@0.0.1 OK for: readable-stream@1.1.14 want: 0.0.1
2849 silly placeDep node_modules/streamroller string_decoder@0.10.31 OK for: readable-stream@1.1.14 want: ~0.10.x
2850 timing idealTree:node_modules/streamroller/node_modules/readable-stream Completed in 4ms
2851 timing idealTree:node_modules/streamroller/node_modules/isarray Completed in 0ms
2852 timing idealTree:node_modules/streamroller/node_modules/string_decoder Completed in 0ms
2853 timing idealTree:node_modules/tar-stream/node_modules/readable-stream Completed in 0ms
2854 timing idealTree:node_modules/tar/node_modules/safe-buffer Completed in 0ms
2855 timing idealTree:node_modules/tar/node_modules/yallist Completed in 0ms
2856 silly placeDep node_modules/thingzi-logic-timers iconv-lite@0.6.3 OK for: needle@3.1.0 want: ^0.6.3
2857 timing idealTree:node_modules/thingzi-logic-timers/node_modules/needle Completed in 3ms
2858 timing idealTree:node_modules/thingzi-logic-timers/node_modules/iconv-lite Completed in 0ms
2859 timing idealTree:node_modules/url/node_modules/punycode Completed in 1ms
2860 timing idealTree:node_modules/util/node_modules/inherits Completed in 0ms
2861 timing idealTree:node_modules/verror/node_modules/core-util-is Completed in 0ms
2862 silly placeDep node_modules/wrap-ansi is-fullwidth-code-point@3.0.0 OK for: string-width@4.2.3 want: ^3.0.0
2863 timing idealTree:node_modules/wrap-ansi/node_modules/string-width Completed in 2ms
2864 timing idealTree:node_modules/wrap-ansi/node_modules/is-fullwidth-code-point Completed in 0ms
2865 silly placeDep node_modules/wrap-ansi ansi-regex@5.0.1 OK for: strip-ansi@6.0.1 want: ^5.0.1
2866 timing idealTree:node_modules/wrap-ansi/node_modules/strip-ansi Completed in 2ms
2867 timing idealTree:node_modules/wrap-ansi/node_modules/ansi-regex Completed in 0ms
2868 timing idealTree:node_modules/xmlrpc/node_modules/xmlbuilder Completed in 0ms
2869 silly placeDep node_modules/yargs is-fullwidth-code-point@3.0.0 OK for: string-width@4.2.3 want: ^3.0.0
2870 silly placeDep node_modules/yargs strip-ansi@6.0.1 OK for: string-width@4.2.3 want: ^6.0.1
2871 timing idealTree:node_modules/yargs/node_modules/string-width Completed in 9ms
2872 timing idealTree:node_modules/yargs/node_modules/is-fullwidth-code-point Completed in 0ms
2873 silly placeDep node_modules/yargs ansi-regex@5.0.1 OK for: strip-ansi@6.0.1 want: ^5.0.1
2874 timing idealTree:node_modules/yargs/node_modules/strip-ansi Completed in 3ms
2875 timing idealTree:node_modules/yargs/node_modules/ansi-regex Completed in 0ms
2876 timing idealTree:node_modules/send/node_modules/debug/node_modules/ms Completed in 0ms
2877 timing idealTree:buildDeps Completed in 71572ms
2878 timing idealTree:fixDepFlags Completed in 42ms
2879 timing idealTree Completed in 71694ms
2880 timing command:update Completed in 71764ms
2881 verbose stack TypeError: Cannot convert undefined or null to object
2881 verbose stack     at Function.keys (<anonymous>)
2881 verbose stack     at module.exports (/usr/lib/node_modules/npm/node_modules/npm-pick-manifest/lib/index.js:213:22)
2881 verbose stack     at RegistryFetcher.manifest (/usr/lib/node_modules/npm/node_modules/pacote/lib/registry.js:125:22)
2881 verbose stack     at async Arborist.[nodeFromEdge] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:1107:19)
2881 verbose stack     at async Arborist.[buildDepStep] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:976:11)
2881 verbose stack     at async Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:218:7)
2881 verbose stack     at async Promise.all (index 1)
2881 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:154:5)
2881 verbose stack     at async Update.exec (/usr/lib/node_modules/npm/lib/commands/update.js:65:5)
2881 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:78:5)
2882 verbose cwd /home/pi/.node-red
2883 verbose Linux 5.10.103-v7l+
2884 verbose node v16.17.0
2885 verbose npm  v8.18.0
2886 error Cannot convert undefined or null to object
2887 verbose exit 1
2888 timing npm Completed in 72251ms
2889 verbose unfinished npm timer reify 1662544397327
2890 verbose unfinished npm timer reify:loadTrees 1662544397385
2891 verbose code 1
2892 error A complete log of this run can be found in:
2892 error     /home/pi/.npm/_logs/2022-09-07T09_53_16_849Z-debug-0.log
Node-RED version : 3.0.2
Node version v16.17.0
Raspberry pi 4
This happened after upgrading Node-RED and Node.js to the latest version. I had run "npm update" before that without any issue. When I update nodes through the graphical interface, that works fine without any problem. Does anyone have a suggestion on how to get rid of this error?
I fixed the issue by moving my .node-red directory to a safe place, then restarting node-red. Then I copied everything except the node_modules directory and the pakage.json file to the new .node-red directory. After another restart of node-red, it started complaining about all the missing modules. I installed those by hand , using npm. Restarting node-red and running npm update once in a while during this proces. In the end, all was ok and things are working again.
