I'm not sure, but if you try to say, that i don't change the frame settings in the function node, i would like to show you this:
I will read the docs again, but i thing i copy the example correct.
There is a little differences between this two nodes (node-red-contribe-xbee-api (node) - Node-RED ) (node-red-contrib-xbee (node) - Node-RED ). Is there example (and need) how to combine them?
Martin, I can only point you to documentation as I dont have any xbee hardware and I have never used it.
All I can suggest is you do more research and learning. Perhaps re-open the issue you raised.
Sorry.
I re-open the issue and still waiting.
I'm trying to remove and reinstall the Xbee node in case there is an error, because I don't see "node-red-contrib-xbee" in the .node-red folder. But when I try to reinstall, it says it's "in use" even though I've removed all the nodes. Any idea?
Colin
18 July 2021 08:55
24
Check for unused nodes in the menu Configuration Nodes and you will probably find the config node that you can delete.
After i did this, now it gave me only to disable it, but not to uninstall ?
Colin
18 July 2021 09:21
26
You still have one in the flow then, probably. Use the Search feature and search for xbee and see if that finds anything.
Colin
18 July 2021 09:40
28
Uninstall it manually then. Go to your .node-red folder and run
npm remove node-red-contrib-xbee
[Edit] Obviously you have to restart node-red after uninstalling it.
I did this command, than restart NR, and it is still the same condition
Colin
18 July 2021 10:43
33
What condition?
Did you refresh the browser?
Yes, i refresh everything
Colin
18 July 2021 11:11
35
Please try and answer all question, I repeat
What condition is it that is still the same?
I can't delete them, only disable
Colin
18 July 2021 12:25
38
In your .node-red folder run
npm list node-red-contrib-xbee
If that shows it still installed then run the remove command again and copy/paste the output from the command here, including the command you ran. Then run the list command again to see if it is gone.
C:\Users\Martin >cd C:\Users\Martin\.node-red
C:\Users\Martin\.node-red>npm list node-red-contrib-xbee
node-red-project@0.0.1 C:\Users\Martin\.node-red
`-- (empty)
Colin
18 July 2021 12:43
40
OK, now show us the startup log for node-red.
And re-confirm that it still appears in the palette manager after a browser refresh.
Yes, i have the same picture, like the above
