I can't figure out how to properly set the herdsman node. Doe anyone have expierence with Zigbee within Node-red?
I'm using myself zigbee2mqtt with this coordinator on a pi. This is not the same pi NR is running on, but that should also be possible.
In NR i'm using the node-red-contrib-zigbee2mqtt (node) - Node-RED node to communicate with the coordinator and devices..
This setup works fine for me.
