NR+XBee Conection
Yes, i try to change it, but i don't know if i fix or mixed up something. Please tell me what specific part of the flow you want me to show you and i will show it to you.
As for the NR...
I really respect this software, because:
  1. It combine variety of elements, that can be integrated into single software platform (in a very elegant way), which is great!
    And also this NR feature is positive and negative (at the same time), because when you try to connect some hardware via library, that NR created, it is hard to find someone to guides you.
  2. It reduce the coding and make it easier to understand it
Any idea?
I still think, that the problem is in NR, because i test the XBee modules within XCTU software and everything there is fine?
