Hi! A few days ago, i tried to use NRF24 node.
The thing is that there's an error ocurring and the module doesn't load up (i can see this in node-red log).
But something strange is happening: when this error occurs, Raspberry Pi's wifi crashes.
I uninstalled the NRF24 node and everything came back to normal.
Does anyone know what might be causing this issue?
Even more also did you see this when you checked for issues on the github page of what I presume is the node you are using. It talks about NR hanging, though that is not the same as the wifi crashing of course.
Hi, i'm sorry, i'm a little new to this.
I've read the doc from https://flows.nodered.org/node/node-red-contrib-nrf24 and installed prerequisites following this https://github.com/ludiazv/node-nrf24.
Node-Red version should be the last one stable 'cause i've updated it and upgraded it yesterday.
The error i was getting, simply said NRF24 working:false and NRF24L01(+): false.
Something i noticed is that i cant find the config to choose whether my module is the common version or the + version (i have the + version).
Colin, I read about it but dismissed it because it's not the same problem.
For two days i was struggling to find the cause of wifi losing connectivity (just in raspberry pi, my phone worked well) few seconds after boot.
I made a fresh raspbian install and wifi worked well, when i reconfigured node red with my nodes, wifi starts to fail again.
The symptoms are: wifi with no conectivity to the network after a minute of booting in spite of saying its connected. If i disable wifi and turn it back on it doesn't show any AP's. On reboot wifi picks again the AP's but after a minute the same happens.
