Object Detection using node-red-contrib-tfjs-coco-ssd
Required nodes in addition to standard nodes (I use the latest current versions):
  • node-red-contrib-image-tools
  • node-red-contrib-telegrambot
  • node-red-contrib-tfjs-coco-ssd
  • node-red-dashboard
  • node-red-node-base64
[{"id":"70f9130a.1f5c0c","type":"base64","z":"2d489fd9.1eedd","name":"","action":"str","property":"image","x":880,"y":530,"wires":[["af833380.f5ea9"]]},{"id":"420b8a89.423b94","type":"http request","z":"2d489fd9.1eedd","name":"","method":"GET","ret":"bin","paytoqs":false,"url":"https://loremflickr.com/320/240/sport","tls":"","persist":false,"proxy":"","authType":"","x":410,"y":430,"wires":[["62e85150.02f7b"]]},{"id":"77fd828a.a6073c","type":"ui_button","z":"2d489fd9.1eedd","name":"","group":"92518872.4d2bc8","order":3,"width":2,"height":1,"passthru":true,"label":"New Picture","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":260,"y":430,"wires":[["420b8a89.423b94"]]},{"id":"18eefa5b.18e276","type":"comment","z":"2d489fd9.1eedd","name":"========== ========== TFJS COCO SSD ========== ==========","info":"\n    ","x":340,"y":490,"wires":[]},{"id":"7c8df2eb.c7408c","type":"inject","z":"2d489fd9.1eedd","name":"test","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":430,"wires":[["77fd828a.a6073c"]]},{"id":"d0f460b0.4bdfd","type":"change","z":"2d489fd9.1eedd","name":"pay to detect","rules":[{"t":"move","p":"payload","pt":"msg","to":"detect","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":530,"wires":[["d6827244.41d64","7a793272.3245fc"]]},{"id":"506351f8.e4c8","type":"link in","z":"2d489fd9.1eedd","name":"coco","links":["23ae07fd.88e498","c710c20f.8d8cb","ed0b6b69.870e78","3d40617c.70e06e"],"x":195,"y":530,"wires":[["e75695c9.dca4e8"]]},{"id":"3d40617c.70e06e","type":"link out","z":"2d489fd9.1eedd","name":"","links":["506351f8.e4c8"],"x":715,"y":430,"wires":[]},{"id":"3ef708a8.692668","type":"comment","z":"2d489fd9.1eedd","name":"coco","info":"","x":130,"y":530,"wires":[]},{"id":"e75695c9.dca4e8","type":"tensorflowCoco","z":"2d489fd9.1eedd","name":"","scoreThreshold":"","passthru":true,"x":290,"y":530,"wires":[["d0f460b0.4bdfd"]]},{"id":"d6827244.41d64","type":"function","z":"2d489fd9.1eedd","name":"Map Objects Boxes get.Picture","func":"//========== retrieves and transmits the image ==========\n//var pictureBuffer = flow.get('pictureBuffer')|| [];\n//msg.pictureBuffer = pictureBuffer;  // send the picture\n\n//========== Detect Empty Objects ==========\nif(empty(msg.classes)){\nmsg.payload = \"no object detected\"  //prepare for the google translate\nmsg.class=\"no object detected\"      //prepare for display in Template Dashboard\nmsg.detect=[]                       //\nreturn msg\n} //no found object \nelse {\n// prepare the color and the thickness of the line in fct of the image size\nmsg.boxcolor = \"yellow\";\nmsg.textcolor = \"yellow\";\n \nif (msg.shape[1] < 300)                             {msg.textfontsize =\"10px\";msg.boxstroke =1;msg.textstroke = \"3px\";}\nelse if (msg.shape[1] >= 300 && msg.shape[1] < 500) {msg.textfontsize =\"15px\";msg.boxstroke =2;msg.textstroke = \"3px\";}\nelse if (msg.shape[1] >= 500 && msg.shape[1] < 900) {msg.textfontsize =\"20px\";msg.boxstroke =2;msg.textstroke = \"5px\";}\nelse if (msg.shape[1] >= 900 && msg.shape[1] < 2000){msg.textfontsize =\"50px\";msg.boxstroke =5;msg.textstroke = \"10px\";}\nelse if (msg.shape[1] >= 2000)                      {msg.textfontsize =\"80px\";msg.boxstroke =10;msg.textstroke = \"20px\";}\n\n//msg.textfontsize =(msg.shape[1] > 600) ? \"70px\" : \"10px\";\n//msg.boxstroke = (msg.shape[1] > 600) ? 5 : 2;\n//msg.textstroke = (msg.shape[1] > 600) ? \"10px\" : \"2px\";\n\n//========== indicates the type of objects and the quantity ==========\n// Get the array of names\nvar names = Object.keys(msg.classes);\nvar firstCount;\n\n// For each name, map it to \"n name\"\nvar parts = names.map((n,i) => {\n    var count = msg.classes[n];\n    if (i === 0) {\n        //Remember the first count to get the \"is/are\" right later\n        firstCount = count;\n    }\n    // Return \"n name\" and get the pluralisation right\n    return count+\" \"+n+(count>1?\"s\":\"\")\n})\n// If there is more than one name, pop off the last one for later\nvar lastName;\nif (parts.length > 1) {\n    lastName = parts.pop();\n}\n// Build up the response getting \"is/are\" right for the first count and joining\n// the array of names with a comma\nmsg.payload = \"There \"+(firstCount === 1 ? \"is\":\"are\")+\" \"+parts.join(\", \")\n// If there was a last name, add that on the end with an 'and', not a comma\nif (lastName) {\n    msg.payload += \" and \"+lastName;\n}\nreturn msg;\n}//fin de si detecte\n\n//========== EMPTY FONCTION ==========\n/*\nHere's a simpler(short) solution to check for empty variables. \nThis function checks if a variable is empty. \nThe variable provided may contain mixed values (null, undefined, array, object, string, integer, function).\n*/\nfunction empty(mixed_var) {\n if (!mixed_var || mixed_var == '0') {  return true; }\n if (typeof mixed_var == 'object') {  \n    for (var k in mixed_var) {   return false;  }\n    return true; \n }\nreturn false;\n}//EMPTY FONCTION END\n","outputs":1,"noerr":0,"x":680,"y":530,"wires":[["70f9130a.1f5c0c"]]},{"id":"62e85150.02f7b","type":"change","z":"2d489fd9.1eedd","name":"","rules":[{"t":"set","p":"topic","pt":"msg","to":"testDetection","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":570,"y":430,"wires":[["3d40617c.70e06e"]]},{"id":"c241e6ec.94fda8","type":"comment","z":"2d489fd9.1eedd","name":"coco","info":"","x":780,"y":430,"wires":[]},{"id":"7defeef9.85baf","type":"comment","z":"2d489fd9.1eedd","name":"========== UPLOAD picture ==========","info":"new picture :320x240\n\n0: object\n    bbox: array[4]\n        0: 127\n        1: 86\n        2: 29\n        3: 90\n    class: \"person\"\n    score: 0.9015087080001831\n    \n    x=127 y=86 width =29  height=90\n    ","x":250,"y":380,"wires":[]},{"id":"af833380.f5ea9","type":"ui_template","z":"2d489fd9.1eedd","group":"92518872.4d2bc8","name":"D3 templatev3 TextStroke","order":1,"width":7,"height":5,"format":"<head>\n    <style>\n        :root {\n        --boxcolor: {{msg.boxcolor}};\n        --boxstroke: {{msg.boxstroke}};\n        --textcolor: {{msg.textcolor}};\n        --textfontsize: {{msg.textfontsize}};\n        --textstroke: {{msg.textstroke}};\n        }\n        .imag {\n            width: 100%;\n            height: 100%;\n        }    \n        #svgimage text {\n            font-family: Arial;\n            font-size: var(--textfontsize, 18px);\n            fill       : var(--textcolor, yellow);\n            paint-order: stroke;\n            stroke: black;/*#ffffff;*//*yellow;*/\n            stroke-width:  var(--textstroke, 3px);/*3px;*/\n            font-weight: 600;\n        }\n        rect {\n            fill: blue;\n            fill-opacity: 0;\n            stroke: var(--boxcolor, yellow);\n            stroke-width: var(--boxstroke, 1);\n        }\n        #svgimage {\n            /*background-color: #cccccc;  Used if the image is unavailable */\n            background-repeat: no-repeat;\n            background-size: cover;\n        }\n    </style>\n</head>\n<body>\n    <svg preserveAspectRatio=\"xMidYMid meet\" id=\"svgimage\"  style=\"width:100%\" viewBox=\"0 0 {{msg.shape[1]}} {{msg.shape[0]}}\">\n        <image  class=\"imag\"  href=\"data:image/jpg;base64,{{msg.image}}\"/>\n    </svg>\n    <!-- \n    <svg preserveAspectRatio=\"xMidYMid meet\" id=\"svgimage\"  style=\"width:100%\" viewBox=\"0 0 {{msg.shape[1]}} {{msg.shape[0]}}\">\n        <image  class=\"imag\"  href=\"data:image/jpg;base64,{{msg.pictureBuffer}}\"/>\n    </svg>    \n    \n    -->\n    <div>{{msg.payload}}</div>\n    <script>\n        (function (scope) {\n            scope.$watch('msg', function (msg) {\n                if (msg && msg.detect) {\n                    var svg = d3.select(\"#svgimage\");\n\n                    var box = svg.selectAll(\"rect\").data(msg.detect)\n                        .attr(\"x\", function (d) { return d.bbox[0]; })\n                        .attr(\"y\", function (d) { return d.bbox[1]; })\n                        .attr(\"width\", function (d) { return d.bbox[2]; })\n                        .attr(\"height\", function (d) { return d.bbox[3]; });\n                    box.enter()\n                        .append(\"rect\")\n                        .attr(\"x\", function (d) { return d.bbox[0]; })\n                        .attr(\"y\", function (d) { return d.bbox[1]; })\n                        .attr(\"width\", function (d) { return d.bbox[2]; })\n                        .attr(\"height\", function (d) { return d.bbox[3]; });\n                    box.exit().remove();\n                    \n                    var text = svg.selectAll(\"text\").data(msg.detect)\n                        .text(function (d) { return d.class; })\n                        .attr(\"x\", function (d) { return d.bbox[0]; })\n                        .attr(\"y\", function (d) { return 10 + d.bbox[1]; });\n                    text.enter()\n                        .append(\"text\")\n                        .text(function (d) { return d.class; })\n                        .attr(\"x\", function (d) { return d.bbox[0]; })\n                        .attr(\"y\", function (d) { return 10 + d.bbox[1]; });\n                    text.exit().remove();\n                }\n            });\n        })(scope);\n    </script>\n</body>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":1060,"y":530,"wires":[["6620cc3f.200064"]]},{"id":"7a793272.3245fc","type":"link out","z":"2d489fd9.1eedd","name":"","links":["892922d6.71f3a","d4e37092.e9a51"],"x":565,"y":580,"wires":[]},{"id":"86e7511.53999b","type":"jimp-image","z":"2d489fd9.1eedd","name":"","data":"image","dataType":"msg","ret":"img","parameter1":"","parameter1Type":"msg","parameter2":"","parameter2Type":"msg","parameter3":"","parameter3Type":"msg","parameter4":"","parameter4Type":"msg","parameter5":"","parameter5Type":"msg","parameter6":"","parameter6Type":"msg","parameter7":"","parameter7Type":"msg","parameter8":"","parameter8Type":"msg","parameterCount":0,"jimpFunction":"none","selectedJimpFunction":{"name":"none","fn":"none","description":"Just loads the image.","parameters":[]},"x":980,"y":660,"wires":[["3797d0ec.4ce87"]]},{"id":"bdfde2a1.a7e7d","type":"ui_template","z":"2d489fd9.1eedd","group":"7b6a751b.c5eb9c","name":"Canvas Selector","order":5,"width":1,"height":1,"format":"    <script>\n    (function(scope) {\n        scope.$watch('msg', function(msg) {\n            if (msg) {\n                // Do something when msg arrives\n                let dataURL = document.querySelector(\"#canvasImage\").toDataURL('image/jpeg');\n                scope.send({payload: dataURL, w: msg.w, h: msg.h});\n            }\n        });\n    })(scope);\n    </script>\n","storeOutMessages":false,"fwdInMessages":false,"templateScope":"local","x":290,"y":780,"wires":[["7643a96c.565538"]]},{"id":"7643a96c.565538","type":"switch","z":"2d489fd9.1eedd","name":"data:image","property":"payload","propertyType":"msg","rules":[{"t":"cont","v":"data:image","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":290,"y":840,"wires":[["e60214af.6cc108"]]},{"id":"d4e37092.e9a51","type":"link in","z":"2d489fd9.1eedd","name":"","links":["7a793272.3245fc"],"x":115,"y":660,"wires":[["97bf55b7.ec4198"]]},{"id":"c06dcfae.24d1b","type":"ui_template","z":"2d489fd9.1eedd","group":"7b6a751b.c5eb9c","name":"Canvas Template","order":7,"width":1,"height":1,"format":"<body>\n<canvas id=\"canvasImage\" width=\"1280\" height=\"720\">\n    Your browser does not support the canvas element.\n</canvas>\n\n<script>\n    (function(scope) {\n        scope.$watch('msg', function (msg) {\n            if (msg) {\n                // Do something when msg arrives\n                function squares(canvasid, squarelist, myimag) {\n                    let canvas = document.querySelector(canvasid);\n                    // hide the canvas\n                    canvas.style.display=\"none\";\n                    canvas.width = msg.shape[1];\n                    canvas.height = msg.shape[0];\n                    let ctx = canvas.getContext('2d');\n                    ctx.scale(1, 1);\n                    let image = new Image;\n                    image.src = \"data:image/jpg;base64,\"+myimag;\n                    image.onload = function () {\n                        ctx.drawImage(image, 0, 0, msg.shape[1], msg.shape[0]);\n                        for (const square of squarelist) {\n                            ctx.lineWidth = 2;\n                            ctx.strokeStyle = 'yellow';\n                            ctx.strokeRect(square.bbox[0], square.bbox[1], square.bbox[2], square.bbox[3]);\n                            ctx.font = \"10px Arial\";\n                            ctx.fillStyle = 'yellow';\n                            let width = ctx.measureText(square.class).width;\n                            ctx.fillRect(square.bbox[0], square.bbox[1]+square.bbox[3], square.bbox[2], 12);\n                            ctx.fillStyle = 'red';\n                            ctx.fillText(square.class, square.bbox[0]+square.bbox[2]/2-width/2, square.bbox[1]+square.bbox[3]+8);\n                        }\n                    };\n                }\n\n                let canvasid1 = \"#canvasImage\";\n                let detect = msg.detect;\n                let imag1  = msg.image;\n                scope.send({payload: detect});\n                squares(canvasid1, detect, imag1);\n                scope.send({payload: 'go', w: msg.shape[1], h: msg.shape[0]});\n            }\n        });\n})(scope);\n</script>\n\n</body>","storeOutMessages":false,"fwdInMessages":false,"templateScope":"local","x":290,"y":720,"wires":[["bdfde2a1.a7e7d"]]},{"id":"97bf55b7.ec4198","type":"base64","z":"2d489fd9.1eedd","name":"","action":"str","property":"image","x":290,"y":660,"wires":[["c06dcfae.24d1b","c445e6a1.625ed8"]]},{"id":"892922d6.71f3a","type":"link in","z":"2d489fd9.1eedd","name":"","links":["7a793272.3245fc"],"x":825,"y":660,"wires":[["86e7511.53999b"]]},{"id":"b5d5d39e.401d9","type":"mqtt in","z":"2d489fd9.1eedd","name":"","topic":"imagetf","qos":"2","datatype":"auto","broker":"2a019090.5ba4d","x":490,"y":380,"wires":[["2dd4729f.4e239e"]]},{"id":"2dd4729f.4e239e","type":"switch","z":"2d489fd9.1eedd","name":"","property":"payload","propertyType":"msg","rules":[{"t":"istype","v":"buffer","vt":"buffer"}],"checkall":"true","repair":false,"outputs":1,"x":600,"y":380,"wires":[["3d40617c.70e06e"]]},{"id":"e60214af.6cc108","type":"ui_template","z":"2d489fd9.1eedd","group":"7b6a751b.c5eb9c","name":"SVG Template","order":2,"width":12,"height":9,"format":"<head>\n<style>\n    .imag {\n        width: 100%;\n        height: 100%;\n    }    \n</style>\n</head>\n<body>\n    <svg preserveAspectRatio=\"xMidYMid meet\" id=\"svgimage\"  style=\"width:100%\" viewBox=\"0 0 {{msg.w}} {{msg.h}}\">\n        <image  class=\"imag\"  href=\"{{msg.payload}}\"/>\n    </svg>\n<script>\n(function(scope) {\n    scope.$watch('msg', function(msg) {\n        if (msg) {\n            // Do something when msg arrives\n            //scope.send({payload: dataURL});\n            //alert(msg.w);\n        }\n    });\n})(scope);\n</script>\n</body>\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":290,"y":900,"wires":[["7aac40f.94f5bc"]]},{"id":"3797d0ec.4ce87","type":"function","z":"2d489fd9.1eedd","name":"draw Rects","func":"const LINE_WIDTH = 2;\nconst LINE_COLOR = 0xED143DFF;\n\nvar jimpImage = msg.payload;\nlet imgW = jimpImage.bitmap.width;\nlet imgH = jimpImage.bitmap.height;\n\n//create clamping functions to avoid printing outside of image\nlet clampX = (val) => clamp(val,0,imgW);\nlet clampY = (val) => clamp(val,0,imgH);\n\n//add imgBatchOps to msg for drawing text in next node \nmsg.imgBatchOps = [];\n\n\nif (msg.detect.length>0) {\n    drawBoxes(jimpImage, msg.detect);\n}\n\nfunction drawBox(img, box) {\n    //get box ccords\n    let x = box.bbox[0];\n    let y = box.bbox[1];\n    let w = box.bbox[2];\n    let h = box.bbox[3];\n    \n    scanHLine(img, x, y+h-14, w, 14, 0xfa758e22); //draw box for text\n    scanRectangle(img, x, y, w, h, LINE_WIDTH, LINE_COLOR);//draw outer rect\n    \n    //built batch operations for next image node to draw text\n    msg.imgBatchOps.push(  \n        {\n            \"name\": \"print\",\n            \"parameters\": [\n                \"FONT_SANS_10_BLACK\",\n                clampX(x+2),\n                clampY(y+h-16),\n                box.class\n            ]\n        }\n        \n    );  \n}\n\nfunction drawBoxes(img, detections) {\n    detections.forEach(element => drawBox(img, element))\n}\n\n\nfunction makeColorIterator(color) {\n  return function (x, y, offset) {\n    this.bitmap.data.writeUInt32BE(color, offset, true);\n  }\n}\n\nfunction scanRectangle(image,x,y,w,h,linePX,color){\n    let iterator = makeColorIterator(color);\n   \n    let xw, yh;\n    x = clampX(x-(linePX/2));\n    y = clampY(y-(linePX/2));\n    w = clampX(w);\n    h = clampY(h);\n    xw = clampX(x+w);\n    yh = clampY(y+h);\n\n    \n    if(y+linePX <= imgH){\n        image.scan(x, y, w, linePX,  iterator);// scan linePX height line - TOP\n    }\n    if(yh+linePX <= imgH){\n        image.scan(x, yh, w, linePX, iterator);// scan linePX height line - BOTTOM\n    }\n    if(x+linePX <= imgW){\n        image.scan(x, y, linePX, h,  iterator);// scan linePX width line - LEFT\n    }\n    if(xw+linePX <= imgW){\n        image.scan(xw, y, linePX, h, iterator);// scan linePX width line - RIGHT\n    }\n    \n}\n\n\nfunction scanHLine(image,x,y,length,linePX,color){\n    let iterator = makeColorIterator(color);\n    x = clampX(x);\n    y = clampY(y);\n    length = clampX(length);\n    if(y+linePX <= imgH){\n        image.scan(x, y, length, linePX,  iterator);// \n    }\n}\n\nfunction scanVLine(image,x,y,height,linePX,color){\n    let iterator = makeColorIterator(color);\n    x = clampX(x);\n    y = clampY(y);\n    height = clampY(y+height);\n    if(x+linePX <= imgW){\n        image.scan(x, y, linePX, height,  iterator);// \n    }\n}\n\n\n//scanCircle(jimpImage, 92, 170, 43, 0x000000FF);\n//scanCircle(jimpImage, 92, 170, 42, 0xFFCC00FF);\n\nfunction clamp(value, min, max) {\n    return Math.min(Math.max(value, min), max);\n}\n\nfunction scanCircle(image, x, y, radius, color) {\n    let iterator = makeColorIterator(color);\n    return image.scan(x - radius, y - radius, radius*2, radius*2, function (pixX, pixY, idx) {\n        if (Math.pow(pixX - x, 2) + Math.pow(pixY - y, 2) < radius*radius) {\n            iterator.call(this, pixX, pixY, idx);\n        }\n    });\n}\n\n \n\nreturn msg;","outputs":1,"noerr":0,"x":980,"y":720,"wires":[["caf53b8c.5f6138"]]},{"id":"caf53b8c.5f6138","type":"jimp-image","z":"2d489fd9.1eedd","name":"add text","data":"payload","dataType":"msg","ret":"img","parameter1":"imgBatchOps","parameter1Type":"msg","parameter2":"","parameter2Type":"msg","parameter3":"","parameter3Type":"msg","parameter4":"","parameter4Type":"msg","parameter5":"","parameter5Type":"msg","parameter6":"","parameter6Type":"msg","parameter7":"","parameter7Type":"msg","parameter8":"","parameter8Type":"msg","parameterCount":1,"jimpFunction":"batch","selectedJimpFunction":{"name":"batch","fn":"batch","description":"apply one or more functions","parameters":[{"name":"options","type":"json","required":true,"hint":"an object or an array of objects containing {\"name\" : \"function_name\", \"parameters\" : [x,y,z]}.  Refer to info on side panel}"}]},"x":980,"y":780,"wires":[["fd02639.baffca","526acc16.b9dfe4"]]},{"id":"5da5b688.b89a88","type":"telegram sender","z":"2d489fd9.1eedd","name":"","bot":"7e82026b.614f0c","x":980,"y":1200,"wires":[[]]},{"id":"c4973d1a.24498","type":"function","z":"2d489fd9.1eedd","name":"","func":"if ('person' in msg.classes){\n    var m = { content:'', type:'', chatId:''};\n    m.content = msg.payload;\n    m.type = 'photo';\n    m.chatId = 1234567890;\n    msg.payload = m;\n    return msg;    \n}\n\n","outputs":1,"noerr":0,"x":980,"y":1140,"wires":[["5da5b688.b89a88"]]},{"id":"da054679.713928","type":"base64","z":"2d489fd9.1eedd","name":"","action":"","property":"payload","x":290,"y":1020,"wires":[[]]},{"id":"fd02639.baffca","type":"jimp-image","z":"2d489fd9.1eedd","name":"","data":"payload","dataType":"msg","ret":"b64","parameter1":"","parameter1Type":"msg","parameter2":"","parameter2Type":"msg","parameter3":"","parameter3Type":"msg","parameter4":"","parameter4Type":"msg","parameter5":"","parameter5Type":"msg","parameter6":"","parameter6Type":"msg","parameter7":"","parameter7Type":"msg","parameter8":"","parameter8Type":"msg","parameterCount":0,"jimpFunction":"none","selectedJimpFunction":{"name":"none","fn":"none","description":"Just loads the image.","parameters":[]},"x":980,"y":840,"wires":[["21c0651b.0bc42a"]]},{"id":"21c0651b.0bc42a","type":"ui_template","z":"2d489fd9.1eedd","group":"7b6a751b.c5eb9c","name":"SVG Template","order":1,"width":12,"height":9,"format":"<head>\n    <style>\n        .imag {\n            width: 100%;\n            height: 100%;\n        }    \n   </style>\n</head>\n<body>\n    <svg preserveAspectRatio=\"xMidYMid meet\" id=\"svgimage\"  style=\"width:100%\" viewBox=\"0 0 {{msg.shape[1]}} {{msg.shape[0]}}\">\n        <image  class=\"imag\"  href=\"{{msg.payload}}\"/>\n    </svg>\n</body>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":980,"y":900,"wires":[["81c1a54d.5c19a8"]]},{"id":"4b8734ac.3cb2ac","type":"base64","z":"2d489fd9.1eedd","name":"","action":"","property":"payload","x":980,"y":1080,"wires":[["c4973d1a.24498"]]},{"id":"81c1a54d.5c19a8","type":"split","z":"2d489fd9.1eedd","name":"","splt":",","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"payload","x":980,"y":960,"wires":[["d309fc02.ddea1"]]},{"id":"d309fc02.ddea1","type":"switch","z":"2d489fd9.1eedd","name":"","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"data:image","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":980,"y":1020,"wires":[["4b8734ac.3cb2ac"]]},{"id":"1fd51178.32a59f","type":"image viewer","z":"2d489fd9.1eedd","name":"","width":"160","data":"payload","dataType":"msg","x":510,"y":960,"wires":[[]]},{"id":"526acc16.b9dfe4","type":"image viewer","z":"2d489fd9.1eedd","name":"","width":160,"data":"payload","dataType":"msg","x":1200,"y":780,"wires":[[]]},{"id":"c445e6a1.625ed8","type":"image viewer","z":"2d489fd9.1eedd","name":"","width":160,"data":"image","dataType":"msg","x":510,"y":660,"wires":[[]]},{"id":"6620cc3f.200064","type":"image viewer","z":"2d489fd9.1eedd","name":"","width":160,"data":"image","dataType":"msg","x":1230,"y":530,"wires":[[]]},{"id":"7aac40f.94f5bc","type":"function","z":"2d489fd9.1eedd","name":"","func":"msg.payload = msg.payload.split(',')[1];\nreturn msg;","outputs":1,"noerr":0,"x":290,"y":960,"wires":[["da054679.713928","1fd51178.32a59f"]]},{"id":"92518872.4d2bc8","type":"ui_group","z":"","name":"Video Capture","tab":"17522d42.149913","disp":false,"width":"7","collapse":false},{"id":"7b6a751b.c5eb9c","type":"ui_group","z":"","name":"NR Image tests","tab":"a0ac7d1b.a925d","disp":false,"width":24,"collapse":false},{"id":"2a019090.5ba4d","type":"mqtt-broker","z":"","name":"","broker":"192.168.0.240","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"7e82026b.614f0c","type":"telegram bot","z":"","botname":"Dummy","usernames":"","chatids":"","baseapiurl":"","updatemode":"polling","pollinterval":"300","usesocks":false,"sockshost":"","socksport":"6667","socksusername":"anonymous","sockspassword":"","bothost":"","localbotport":"8443","publicbotport":"8443","privatekey":"","certificate":"","useselfsignedcertificate":false,"sslterminated":false,"verboselogging":false},{"id":"17522d42.149913","type":"ui_tab","z":"","name":"Video Capture","icon":"dashboard","order":3,"disabled":false,"hidden":false},{"id":"a0ac7d1b.a925d","type":"ui_tab","z":"","name":"XXX","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
As example, these images are handled excellent by the coco ssd analyze. Some other analyzers I have tested had problems detecting me walking there. The camera is looking down from the roof so no real frontal views that should have been ideal
Walter, this is awesome! And your flow is very compact.
When I started with Node-RED a couple of years ago, this was the kind of stuff that I wanted to achieve.
Finally we are getting closer to a pure Node-RED based video surveillance solution.
Just love it :+1: :+1: :+1: :+1: :+1: :+1:
a little bug that won't happen often. If we compare it to my flow :
The problem is the very loose calculations for position of lines and rectangle for underneath text.
We don't have the luxury of a client side DOM with a plethora of elements and functions - at sever side, we have a bitmap of pixels and we have to calculate which pixels to set.
With a bit more work, we could easily determine form the rectangles coordinates in relation to the bitmap extent & place the string appropriately.
Edit...
On the lighter side, we (humans) can see it's a person haha.
(the annotation is really only for visual debugging - I think :slight_smile: ).
I just have to tell you I have finally got something also working for my NVIDIA Jetson Nano's (arm64)!!! So happy!
I raised an issue earlier regarding missing support for node-tfjs on arm64 platforms
Luckily for me, @yhwang kindly reached out and provided a solution
Maybe this is useful for RPi4 users as well?
Anyway, now I can run Node-RED on my Jetson Nano's with tfjs-coco-ssd detection built-in!
Can you share this flow please?
Of course, right away...
I found out that some additional nodes also are needed. I installed them via palette manager before I imported the flow (image-tools you have already I think :wink: )
Best regards, Walter
"dependencies": {
"@tensorflow/tfjs-node": "1.4.0",
"node-red": "^1.0.3",
"node-red-contrib-browser-utils": "0.0.9",
"node-red-contrib-image-tools": "^0.2.5",
"node-red-contrib-post-object-detection": "^0.1.2",
"node-red-contrib-tf-function": "^0.1.0",
"node-red-contrib-tf-model": "^0.1.6"
[{"id":"1545e935.999977","type":"jimp-image","z":"bfd6731.db3089","name":"load the image","data":"payload","dataType":"msg","ret":"buf","parameter1":"","parameter1Type":"msg","parameter2":"","parameter2Type":"msg","parameter3":"","parameter3Type":"msg","parameter4":"","parameter4Type":"msg","parameter5":"","parameter5Type":"msg","parameter6":"","parameter6Type":"msg","parameter7":"","parameter7Type":"msg","parameter8":"","parameter8Type":"msg","parameterCount":0,"jimpFunction":"none","selectedJimpFunction":{"name":"none","fn":"none","description":"Just loads the image.","parameters":[]},"x":360,"y":140,"wires":[["8721e9e0.e949e8","d775e36d.cc825","11e3829b.dec12d"]]},{"id":"8721e9e0.e949e8","type":"image viewer","z":"bfd6731.db3089","name":"Original Image viewer","width":"320","data":"payload","dataType":"msg","x":940,"y":140,"wires":[[]]},{"id":"5606b167.a042b","type":"image viewer","z":"bfd6731.db3089","name":"With bounding boxes","width":"320","data":"payload","dataType":"msg","x":660,"y":570,"wires":[[]]},{"id":"7ceb8aa5.98cbe4","type":"bbox-image","z":"bfd6731.db3089","name":"bounding-box","x":570,"y":500,"wires":[["5606b167.a042b"]]},{"id":"dd52b9b3.e03978","type":"change","z":"bfd6731.db3089","name":"objects","rules":[{"t":"set","p":"complete","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":360,"y":430,"wires":[["11e3829b.dec12d"]]},{"id":"bcf6963a.e2f4e8","type":"post-object-detection","z":"bfd6731.db3089","classesURL":"https://s3.sjc.us.cloud-object-storage.appdomain.cloud/tfjs-cos/cocossd/classes.json","iou":"0.5","minScore":"0.5","name":"post-processing","x":360,"y":360,"wires":[["dd52b9b3.e03978"]]},{"id":"d775e36d.cc825","type":"tf-function","z":"bfd6731.db3089","name":"pre-processing","func":"const image = tf.tidy(() => {\n  return tf.node.decodeImage(msg.payload, 3).expandDims(0);\n});\n\nreturn {payload: { image_tensor: image } };","outputs":1,"noerr":0,"x":360,"y":210,"wires":[["8bee1dc1.4ecca"]]},{"id":"8bee1dc1.4ecca","type":"tf-model","z":"bfd6731.db3089","modelURL":"https://storage.googleapis.com/tfjs-models/savedmodel/ssdlite_mobilenet_v2/model.json","outputNode":"","name":"COCO SSD","x":350,"y":280,"wires":[["bcf6963a.e2f4e8"]]},{"id":"11e3829b.dec12d","type":"function","z":"bfd6731.db3089","name":"","func":"let queue = flow.get('queue');\nif (queue === undefined) {\n    queue = [];\n    flow.set('queue', queue);\n}\n\nif (msg.complete === undefined) {\n    queue.push(msg.payload);\n    node.done();\n} else {\n    const image = queue.shift();\n    node.send(\n        {\n            payload: {\n                objects: msg.payload,\n                image: image\n            }\n        });\n}","outputs":1,"noerr":0,"x":565,"y":430,"wires":[["7ceb8aa5.98cbe4"]],"icon":"node-red/join.svg","l":false},{"id":"f8135785.7c4808","type":"mqtt in","z":"bfd6731.db3089","name":"","topic":"epic","qos":"2","datatype":"auto","broker":"a5576de4.82b","x":140,"y":140,"wires":[["1545e935.999977"]]},{"id":"ff74da07.dd21f8","type":"fileinject","z":"bfd6731.db3089","name":"","x":150,"y":100,"wires":[["1545e935.999977"]]},{"id":"a5576de4.82b","type":"mqtt-broker","z":"","name":"","broker":"192.168.0.240","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
Ah now I understand. It uses node-canvas for the drawing. So it inherits the canvas capabilities - good workaround for the limited drawing capabilities of jimp.
Do you mean you use now the tf-model node instead of the coco-ssd node? And is Jetson Nano a better choice (instead of a rpi 4) for this kind of stuff?
The analysis is not always correct.
E.g. the analysis of this picture results in a motorcycle instead of a car:
I have told my wife so many times that she should be careful when parking our Volkswagen :thinking:
Sorry for this amateurish interruption of a professional discussion ...
In addition, it was an almost new car! :laughing:
Yes, I too see the same problem: plants are detected as People and create false alerts through the loudspeaker of the house at 2:00 am: "There is a person in the garden" :woozy_face:
By doing research in the other examples of flow I found this one:
https://miro.medium.com/max/1400/1*h6Vz9fIQJRoASHOK0uKHGg.gif
It is based on Teachable Machin by google. Using a webcam we take the object from various angles, backgrounds, lighting ... To improve the model, we can add other photos.
The result is a tensorflow.js model, the url of which must be entered in the detection node. Or registered locally. So simple.
To test ...
Yes, currently, on the Jetson Nano I use the tf-model node and it is stated that the GPU is used. To make the coco-ssd-node work I suspect that it has to use the updated @tensorflow/tfs-node but I do not know how to make that happen, I have some ideas experimenting, like running "npm install" in node-red-contrib-tfjs-coco-ssd directory to rebuild the bindings, but I don't know
EDIT: I do not know but I do suspect that it is problematic to use the node-red-contrib-tfjs-coco-ssd node on a RPi4. Maybe someone already tried?
If the Jetson Nano is a better choice then the RPi4 for this kind? Well, I don't know. What I know is that the Nano can do impressive real time video analyzes at a high speed when using other tools & libraries specifically written for it. But I'm not sure if it's power is really utilized when running everything through NR.
So very true :smiley:
On the other hand, my wife once worked with a company handling customer fleets (car leasing) and you cannot believe how many calls started "My wife...". In reality, it was not the wife...
Very interesting!!!
This decrease in inferencing time brings the Raspberry Pi 4 directly into competition with both the NVIDIA Jetson Nano and the Movidius-based hardware from Intel
For the most curious the link of the comparison (very instructive). The difference between Tensorflow and TensorflowLight is obvious:
So I managed to make the coco-ssd-node work on Jetson Nano!!! This is how it worked for me:
Install both nodes:
In the folder "/home/user/.node-red/node_modules/node-red-contrib-tfjs-coco-ssd/node_modules/@tensorflow" delete the following folders
  • tfjs-node
  • tfjs-converter
and then replace with the same folders from the folder "/home/user/.node-red/node_modules/@tensorflow"
After this the coco-ssd node also works on arm64!
I was able to test the detection of objects but on the pi3 there is a memory consumption that increases without ever going down.
After about 10 detections it blocks. It is necessary to restart NR.
Was this already mentioned-resolved in another post? If so, sorry :face_with_hand_over_mouth:
If not, do you have ideas to solve this problem?
I attach a CPU & Memory visualization to each detection.
mémoire-cpu
NR-LOG
I'm having the exact same issue in a RPi 4.
I had to write a flow that restarts Node Red once it it 60% or Ram consumed.
Which version of the node are you using ? Can you try shrinking the images before sending them to the node. (While it shouldn’t matter the models only need about 320 x 240 px)
here I have programmed a resizing of the images captured by the cameras at 320x240. Since 2 hours, I have not exceeded 90% of use (Ram 1 GB). I will let it run for a few days to see...
In an other hand, more and more people complain of memory leak when using tfjs:
It seems that using the td.tidy() method and the tf.disposeVariables function solves the problem.
@dceedjay does that mean anything to you? Can it be useful to solve our problem?
worth a try - pushed a version 0.4.1
not sure if I've implemented it correctly - so any help / advice gratefully received...
