Hello evrey one,
have an issue with the Helix ODBC node. I'm passing three messages from function node with three different queries (tested and correct), but it returns three identical messages related to the results of the last received query. Could it be a cache issue?
thanks
Colin
16 October 2023 11:29
2
Welcome to the forum @Riccaleu
The most likely cause of this is that you are re-using the same msg object in your function. In javascript objects are stored by reference, so if you do, for example,
msg.payload = "something"
node.send(msg)
msg.payload = "something else"
node.send(msg)
then the second msg.payload = statement will overwrite the payload of the message you have just sent, which the ODBC node will not yet have actioned.
One solution is to clone the existing message each time
msg1 = RED.util.cloneMessage(msg)
msg1.payload = "something"
node.send(msg1)
msg2 = RED.util.cloneMessage(msg)
msg2.payload = "something else"
node.send(msg2)
You won't need to clone for the third one.
If that isn't it then post the code of the function. Copy/paste please, not screenshot.
See also Cloning messages in a flow : Node-RED which goes into cloning and pass by reference in more detail.
Thanks for the quick reply
i have a message for each i element could be thousand
here the code
var query = ""
for (var i = 0; i < length; i++) {
query =
`SELECT
var msg = {}
msg.query = query
msg.dsn = global.get("dsn");
node.send(msg);
Switch to using let or not use a key identifier like msg along with var
var will apply to outside the scope - and if you use msg with var - you are affecting the msg that is still travelling during the cycle
for (let i = 0; i < length; i++) {
let query = `SELECT...'
let msg = {}
msg.query = query
node.send(msg);
Examples
var msg = {"Hello": "World"}
for(var i = 0; i<10;i++){
var msg = {"What": "The!"}
node.send(msg)
// msg is now surprisingly {"What": "The!"}
for(let = 0; i<10;i++){
let msg = {"What": "The!"}
node.send(msg)
// msg is still {"Hello": "World"}
Colin
16 October 2023 12:16
5
Which is one of the reasons why var is now deprecated. Use let or const instead.
Thanks for the suggestion,
i applied let for each variable but unfortunately nothing change
can you share whole function block?
yes , for privacy i need to mask some stuff`
context.data = context.data || {};
switch (msg.topic) {
case "string":
context.data.string = msg.payload.items;
msg = null;
break;
let IdWL = context.data.string
let dateStart = new Date();
dateStart.setMinutes(0);
dateStart.setSeconds(0);//arrotondo alll'ora intera corrente
let dateEnd = new Date();
dateEnd.setDate(dateEnd.getDate() - 5)
dateEnd.setHours(0);
dateEnd.setMinutes(0);
dateEnd.setSeconds(0);
let dataStartFormat = dateStart.toISOString().replace('T', ' ').substring(0, 19);
let dataEndFormat = dateEnd.toISOString().replace('T', ' ').substring(0,19);
for (let i = 0; i < IdWL.length; i++) {
let msg ={}
let query =
`SELECT
ID,RECORDTIME, VALUE
FROM
HIS15MIN
WHERE
ORDER BY
"RecordTime" ASC`
msg.query = query
msg.toipic = IdWL[i].pointId
node.send(msg);
Thanks a lot
E1cid
16 October 2023 13:16
9
What happens when you rate limit the output of the function node using a delay node set to rate limit? giving enough time to run each query.
Colin
16 October 2023 13:33
10
The spelling there looks suspect.
As well as rate limiting as suggested, feed the output of the function node into a debug node set to Output Complete Message and check that they look correct.
Thanks It works!
but i don't think is the best way to solve the problem , at least not the most efficient one, i'd like to menage it trougth waiting the message to complete its path or something like this
sorry,
just an error of writing. results in debug are ok!
E1cid
16 October 2023 13:41
13
knowing nothing about the node forward makes it hard to help further.
You can use rate limit as a queue. To make it more efficient once your sql node responds you can feed msg.flush set to 1 back to the delay node to release next. Read help text for delay node, both Colin and me have posted example flows for this in the past.
here is one
Will queuing the inputs and only allowing new input once tcp responds work
[{"id":"7f219818a234a3c6","type":"inject","z":"d1395164b4eec73e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"eeeeee","payloadType":"str","x":510,"y":520,"wires":[["3b447fd41df4372d"]]},{"id":"3b447fd41df4372d","type":"function","z":"d1395164b4eec73e","name":"add \"\\r\\n\"","func":"msg.payload = msg.payload + '\\r\\n';\nreturn ms…
If you mean that you have a section of flow and you want to wait till one message has completely passed through that section before the next one is allowed through then have a look at this example of how to do it. Set the time in the Queue node to a greater time than your flow should ever take to run through. If something locks up then it will release the next message after that time in order to let things keep going.
[image]
[{"id":"b6630ded2db7d680","type":"inject","z":"bdd7be38.d3b55","n…
Just to add some input, which I think is related??
a Semaphore node that was discussed above, had some issues, so I addressed them with my take on a Semaphore Node (with a lot of extras)
It may come in handy to address the discussed
