I have been re-factoring some of my flows to make better use of node status messages and have run into a few quirks and possible bugs. I will try to post about them over the next few days. Here is the first.
19 Aug 19:30:10 - [info] Node-RED version: v0.20.6
19 Aug 19:30:10 - [info] Node.js version: v8.11.2
19 Aug 19:30:10 - [info] Darwin 18.7.0 x64 LE
With this flow,
[{"id":"f6acdf91.d5683","type":"status","z":"d141e924.5365a8","name":"status:mqtt","scope":["8b571501.8e06c","56474d5.75b57b4"],"x":270,"y":100,"wires":[["4aef2ae4.569564"]]},{"id":"4aef2ae4.569564","type":"debug","z":"d141e924.5365a8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"status","targetType":"msg","x":450,"y":100,"wires":[]},{"id":"56474d5.75b57b4","type":"mqtt out","z":"d141e924.5365a8","name":"","topic":"","qos":"","retain":"","broker":"74015cbe.beb164","x":110,"y":60,"wires":[]},{"id":"4f2b7cdb.58c2fc","type":"e-mail in","z":"d141e924.5365a8","name":"","protocol":"IMAP","server":"imap.gmail.com","useSSL":true,"port":"993","box":"INBOX","disposition":"Read","criteria":"UNSEEN","repeat":"300","fetch":"auto","inputs":0,"x":110,"y":220,"wires":[[]]},{"id":"c0636354.a988b","type":"status","z":"d141e924.5365a8","name":"status:email","scope":["4f2b7cdb.58c2fc"],"x":270,"y":220,"wires":[["56c02f7a.076c88"]]},{"id":"56c02f7a.076c88","type":"debug","z":"d141e924.5365a8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"status","targetType":"msg","x":450,"y":220,"wires":[]},{"id":"8b571501.8e06c","type":"mqtt in","z":"d141e924.5365a8","name":"","topic":"/","qos":"2","datatype":"auto","broker":"74015cbe.beb164","x":110,"y":140,"wires":[[]]},{"id":"74015cbe.beb164","type":"mqtt-broker","z":"","name":"","broker":"test","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","closeTopic":"","closeQos":"0","closeRetain":"false","closePayload":"","willTopic":"","willQos":"0","willRetain":"false","willPayload":""}]
on startup or restart, the e-mail and mqtt nodes display the correct status in the editor, but the status node connected to the e-mail node receives the status text
"email.status.connecterror", and the one connected to the mqtt nodes receives "node-red:common.status.connecting". I suspect this comes from a problem in retrieving the proper strings from a lookup, and the developers will know exactly where to look.
