I'm trying to call an OPC-UA method. Input parameters are handled in a function node.
msg.objectId = "ns=2;s=Sinumerik";
msg.methodId = "ns=2;s=/Methods/Filehandling/Select";
//msg.fname=flow.get("fname");
msg.inputArguments = [
{ dataType: "String", value: "Sinumerik/FileSystem/Work Pieces/TECHNIKER/MESS.MPF"},
{ dataType: "UInt32", value: 1}
Error:Execute method result, error:The node id refers to a node that does not exist in the server address space.
Copied the identifier from UAExpert:
I'm not sure if the identifier of the method or of the input argument is the problem.
If I call the method in UAExpert directly it works.
Any thoughts about this?
Thx,
Steve
