Hello, I want to edit my ui template code in vscode. Is this possible?
node-red node settings are not saved as individual files, but as part of a single JSON file so no, not directly but there is nothing to stop you copy
paste
edit
copy
paste.
Are you using node-red v3+? The code editor in the template node is "Monaco" - the same underlying editor as vscosde uses.
yes I am using the Node-RED version: v3.0.2. This is what my template node's code editor looks like:
If you are wanting to do custom front-end code in Node-RED, you could use uibuilder but unless you know AnguarJS, you will have to create things in a different way to Dashboard.
