Is there any node that allows me to open a web page using its URL adress ?
Not sure I know what you mean. The flow executes on the server not the browser. So where would this web page be seen? The http request node can go and get a web page which you can then parse.
If you want the dashboard to link to another site use a ui-template node. Here is an example that will link to google.
[{"id":"71bd6044.791278","type":"ui_template","z":"27e6a447.75ae8c","group":"d8596899.c56458","name":"","order":0,"width":0,"height":0,"format":"<div>\n <a href=\"http://google.com\"><span>Google</span></a>\n</div>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":580,"y":300,"wires":[[]]},{"id":"d8596899.c56458","type":"ui_group","z":"","name":"Default","tab":"ae47cffa.963c78","disp":true,"width":"6","collapse":false},{"id":"ae47cffa.963c78","type":"ui_tab","z":"","name":"Home","icon":"dashboard"}]
yeah that's what i'm searching about , thank you a lot ![]()
is there any other solution ? a node for example ?
i want juste to make a link to a certain site
In the right panel of the dashboard editor you can add a link
Good idea ! thank you
In case I want to open a web page with query parameters like "www.google.com?x=1&y=2 the character & makes the above example non functioning due to error. How do I change (encode) the request so that I can add more parameters?
Actually my aim is to have a link to google maps api with lat and lon as parameters. The link would be in the node-red UI and when clicking a new page should open showing the map. Those location parameters will come from a gps IOT device installed on my boat.
Thanks in advance for any help.
it works for me
[{"id":"5f91d80d.9b428","type":"ui_template","z":"eaea399f.2dd2e8","group":"2007caa7.9dc636","name":"","order":0,"width":0,"height":0,"format":"<div>\n <a href=\"http://www.google.com?x=1&y=2\"><span>Google</span></a>\n</div>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":370,"y":152,"wires":[[]]},{"id":"2007caa7.9dc636","type":"ui_group","z":"","name":"Default","tab":"ad0e1f68.c10fd","disp":true,"width":"6","collapse":false},{"id":"ad0e1f68.c10fd","type":"ui_tab","z":"","name":"Home","icon":"dashboard"}]
As always I will add a plug for https://flows.nodered.org/node/node-red-contrib-web-worldmap
as we already have some boat friendly layers built in.
If I copy this from your post to my node-red without modifications, I got a red error mark on line 2 saying "Named entity expected. Got none". If I then add a space between & and y the error goes away, but obviously that is not an acceptable url.
Any hints?
Wow, I didn't know about this. Very interesting. Thanks!
What version of node-red-dashboard are you using?
It's v0.19.4
Oh, sorry, my bad :). It was 2.13.0 so I updated it to the latest. Still same error visible.
But now I noticed that in case I deploy despite of this error mark, it works OK. Do not know if that is due to the latest version because I think I couldn't deploy earlier when this error was shown.
It would be interesting to know what is the reason in case you do not see the error mark, but I can live with this as it seems to do what I need now.
Thanks for the help.
If you can it's probably worth upgrading to v0.20.x as well... If you installed it yourself on a pi there's a simple upgrade script on the raspberry pi page in the docs
In valid HTML the & indicates the start of an entity reference. So although it's a valid character in a URL (as you type it on the location bar in your browser), it's not correct within an HTML document.
To be "correct" you should replace the & in the href= with & which would result in:
<a href="http://www.google.com?x=1&y=2">
Which will work correctly and remove the flagged error.
The error given is a real error, but what you have got there is such a common mistake that browsers have been coded to "do the right thing" in this situation.
Hope that helps, if a little late.
Thanks for the good explanation Chinchilla. It helped to understand the reason for the error.
